Results 1 to 7 of 7
Thread: the new mods for the 83R
    Dec 2002
    deer park, texas
    2,336
    well i just ordered my 34mm flatslide carb and 86r reed cage for the r. i am also going to put me a new pipe and silencer on. now my question is were should i start my jetting. jetting has always kicked my butt. so all info you can give will help. i was going to get a dial a jet, but i am not sure how well this concaction is going to work. i know my jet is going to be lower then normal on the air cooled r. so i dont know if the dial a jet will accomplish this.
    Dec 2002
    deer park, texas
    2,336
    does anyone have any ideas
    Washingtons Crossing, Pa.
    2,977
    Whats the 34mm carb off of ?.
    Mar 2004
    North Central Ohio!!
    2,712
    Just start with the stock jet. Should be around 145-150 ( I think ) I'm pretty sure I'm running a 150 in mine now, but the warmer it is, the less jet you need. Your carb probably has a 145 in it, and you'll end up real close to that, when your finished. Hard to say in Texas. That's quite a bit different climate from here in Ohio.
    Dec 2002
    deer park, texas
    2,336
    well every used carb i looked at is up north so i know whatever it is jetted at will definetly be wrong. the carb is off an 86R. if i remeber right i am going to haveeto do some airbox modifications but i do not think they are that severe.
    Jun 2004
    potsdam ny
    1,227
    call sudco! they know there s#!T when it comes to jetting, mine was only offby one size, but i always order one up and one down from what they recommend, i would use the needle they recommend too....
    Poplar, WI
    531
    I put a dial-a-jet on mine and it has worked great....the only problem with her know is a lack of brakes. I too, would start at stock jet settings and work from there.
    1983 250R ~ 1984 125M ~ 1990 POWER WHEELS!! trike
