Originally Posted by
MO350X
Yeah, I know this sounds a bit jerry-rigged but it saved me:
Mine only stripped the "tips" of the nut off.
So I found a standard, non-metric, socket (can't remember what size) and tapped it onto the bad lug with a
Tap it on as FAR as possible or you'll only make it worse!
I was then able to get the lug loose then used the
to tap the socket off, removing the lug the rest of the way with my hand.
That's a LOT faster than drilling and cutting.
Good luck!
I had the same suggestion as MO350X, but will add to use an impact wrench to remove the nut rather than a ratchet. The extra oomph provided by the impact wrench may be all you need to get it done.
Current Ride (Purchased new in Oct. 84) - 1985 Honda ATC 250R w/ ESR 310cc big bore kit
Wife's Ride - 2009 Polaris RZR 800
Kid's Rides - 2009 Yamaha Raptor 700, 2008 Yamaha Raptor 250
Former Rides - 1975 Honda XR 75, 1979 Yamaha IT 175, 1978 Honda ATC 90, 1980 Honda ATC 110
got sand?
