Results 1 to 15 of 15
Thread: How do you install grips?
    Jan 2005
    RI
    2,530
    I searched, and I couldnt believe that no one asked that question before (maybe im just stupid.)
    But, how do you install a set of new grips on clean, chrome handle bars like on my 200s? I heard in some threads you guys would put some gas on them or something like that. Also, how do you make it so they slide on somewhat easy, then become nice and tight afterwards?
    Please help a poor fool out.
    Thanks,
    Mike
    Feb 2005
    Oregon
    772
    I used rubber cement to put them on my 20" BMX bike, it worked great and they never slipped over the 2 years that they have been on.
    1986 310R
    1975 F150 4x4
    1975 F250 4x4
    1968 F100 2wd
    2001 Dodge 1500 4x4
    Jun 2004
    Oregon
    1,782
    I use paint myself but thats just me..I guess hair spray works too....
    1986 ATC 250R
    Ported w/ Cool head
    LED pipe and silencer.
    Vforce3
    Keihin PWK 38mm
    Works Ultra Cross Shock
    LSR +2 Axle
    American Star Racing +4 Swinger
    LED Intake
    Hi-Flite desert seat
    OEM clutch 89 upgrade
    2021 YFZ450Rse Rossier R5 Titanium Header AIS Delete FCI Vortex ECU
    Howdy's Avatar
    Celina, Ohio
    10,079
    I use a air gun. The expand and slide right on. Removing the old ones is a snap this way also.
    Howdy
    Mar 2005
    overton, PA
    5,257
    i use sandable primer it goes on wet and dties with a texture.to hold it on.
    Roanoke, VA
    4,038
    Liquid Nails works great for making grips stick...I put that on my SX grips and they havent slipped or moved for 5 years
    [20:55] <waterpumper> putting a racing pipe on a Foreman is like putting a high dollar bikini on a 400 pound chick...just because it fits doesn't mean it looks cool
    Pa.'s Highest City
    8,058
    I usually just cut the old ones off or shove a flathead screwdriver down in there then spray some wd-40 they slide right off. To keep them on I know they sell something (can't remember what's it called) at my local cycle shop in a spraycan. But I have used everything from hairspray to superglue to doublesided tape. They all work.
    RichinMO's Avatar
    RichinMO is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2002
    Waynesville, MO
    321
    A guy I know said you can drop the grips in boiling water for a little bit, that makes them expand so they slide right on and then when they cool and dry overnight, they are on there tight. I haven't tried this so I cannot vouch for this procedure.
    1985 ATC250ES
    1985 ATC250SX
    1984 ATC200S "Little Red" - Trailer hitch, Hondaline: Front and Rear Racks, Cooler Rack, Tripmeter, HL Grille, Rubber Footpeg Covers, Mudflaps.
    1985 ATC70
    2008 CRF230L - Dual Sport
    2016 TRX500 Foreman Rubicon Deluxe
    Phoenix, AZ.
    6,719
    I always used spray paint but this last time I tried the Scott grip glue. My god what a PITA those grips were to put on. That stuff dries way too fast but they're on solid once you're done.
    Washingtons Crossing, Pa.
    2,977
    I pour a little rubbing alcohol in them, swish it around, pour it out, put a little on the bars - then they go on like butter and shrink back tight over the bars when the rest of the alcohol evaporates. I've been using that trick for 20 years.
    Jun 2004
    geraldton, west australia
    1,068
    i use KY jelly...or hairspray
    LIVELOVERIDEDIE
    1981 Honda Atc 124R-Racer project
    2005 Giant STP 1- rollin' on 26's
    leprogle's Avatar
    leprogle is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2003
    New Brunswick
    345
    lol. ky jelly. just goes to show EVERYTHING IS better with lube
    Caution
    Do not "POP WHEELIES" and run for any distance with the ATC. The oil capacity is relatively small and the oil will drain out of the oil pump area thus causing loss of oil pressure, resulting in costly engine damage -CLYMER
    Mar 2004
    Newnan, GA / Near Atlanta
    1,727
    Thumbs up
    I cut the old ones off with a razor blade and $#%# can them then spray WD-40 inside the new grips, and slide them on with ease. Put the bike in the sun for a little bit to let them dry out and then im done. They dont budge. The wd-40 evaporates off while its in the sun.
    Clay Whitman
    Newnan, GA
    AMSOIL DEALER
    My Toys
    2008 Yamaha Rhino 700 SE
    1999 Larson 226 SEI 5.0L EFIVolvo I/O LOVE IT
    Belsano, PA
    1,387
    I like the AirHose method. Just did it last night. If ya don't have air, go with some form of fast evaporating spray like the others posted. It works good too. To get them off, razor blade if they are worn out and are being tossed, screwdriver and WD-40/silicone spray like ChrisR said.
    toyota200x's Avatar
    toyota200x is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2003
    402
    Shuv a flat bladed screwdriver under the grip and then spray windex under the grip to get it off. To keep the new grips tight spray hair spray in the grips and slide them on. Let them sit for a couple hours. I have had good luck with the hair spray on bikes.
    Owner of
    '98 klx 300r
    '85 250sx
    '82 185s
