Results 1 to 8 of 8
Thread: What's the difference tween 85 & 86 250R axles?
    Dec 2002
    15
    I have an aftermarket axle for a 250R in my garage. Just not sure which year it is for.
    BTW, it's 37 5/8" wide. How wide is a stock axle??
    Dec 2002
    15
    Can anyone please give me a hand, I really want to sell it?
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,244
    85 alxe,, the sprocket bolts on the outside of the hub,,,on the 86 and later the sprocket bolts on the inside of the hub,,,the axle i measured is stock and 35 and 3/4 inches wide,,,,,,,
    Jun 2004
    potsdam ny
    1,227
    ive been told that all 85-89 250R axles are exactly the same, as far as fitting.....the only difference is some hardware that goes on the axle....
    Dec 2002
    15
    So if the sprocket hub is not on the axle, you cannot tell the difference between an 85 or 86?
    Jan 2004
    Palmetto,Florida
    2,300
    Also the 86 was hollow and the 85's were solid..they didn't bend as easy...not sure about the splines if they inter change with one another...GOOD LUCK !!
    "07" DR650 Suzuki Dual Sport
    Ventura, CA
    87
    trx, how much for the axle & can I see pics?
    86 ATC 250R- Black plastics, black Acerbis headlight, Pro-taper bars (CR bend), 18" Holeshots, K&N filter,Turbine Core silencer.
    85 ATC 250R- Bills pipe and silencer, 3.5 gallon desert tank, West Coast +4 swingarm, Keihn Airstryker 38mm carb, port and polished, and YZ blue and white plastics.
    Dec 2002
    15
    I was gonna have it chromed then put it on eBay. I'd like to get $125 for it. My buddy does chroming so I get that for nothing.
    Here are some pictures.
    SO WHAT YEAR IS THIS THING??
    Attached Thumbnails Attached Thumbnails P1000562.JPG   P1000566.JPG   P1000567.JPG
