Thread: 83-85 swingarm weak point?...
    May 2003
    Shediac, New Brunswick
    1,126
    I have 3 200x swingarms.. 2 that are "trash" because the bearing area is stretched ... does this happen to them all?.. anyone know how to fix it?
    Is it common??! Let me know
    '04 450r, hr +3 stroker, s2 hotcam
    '84 Honda 200x
    slow restro
    Previous rides 82 Yamaha yt175, 85 Yamaha 225DR, 84 Honda 200M, Ski-doo Olympic 340
    Aug 2004
    Ab Canada
    4,368
    what do you mean the bearing area is "streatched" if the race's are warn im shure a good welder/machinest could strighten them out
    1985 Tri-Z-
    May 2003
    1,126
    well its like when you put the bearings in they just move around... they are loose.
    '84 Honda 200x
    slow restro
    Jan 2005
    Slatington PA
    4,372
    Definitly is a weak point. I know exactly what you are referring to.
    The slots in the rear that pinch the outer housing tight on the chain adjustment cam -bearing assembly, get expanded or explode under more extreme conditions.
    I had just this happen to my R side on my 250X 4 wheeler. It is basically the same swingarm or identical. Took it off and had it welded up to stronger then new.
    While the chain adjustment system is great, having those slots in the rear must weaken it up for sure. Under normal use they are fine but if you motx it like i did thats when the "problem" will show up.
    Oops, you have the 83-85 model. I was referring to 86 & 87. The situation might be somewhat simular to what I am referring to though. Yours doesn't have the slots though.
    May 2002
    610
    replace the bearings at regular intervals and it should last forever
    Sam from Florida
    1985 BIGRED $ 200X
