Results 16 to 30 of 31
Thread: I just stole a Scrambler 400
    NE. Ohio
    484
    Quote Originally Posted by Wickedfinger
    The '99 has the concentric drive system, but is not the newer "10.5" Long travel shock. If your shock is sluggish, I have a good '99 Fox Shock if you are interested in it.
    The shock thats on it seems pretty good and dosn't really have any sag. Strange that It would sit that low from the factory. I guess thats why they changed it for 2000. Couldn't I put the 10.5" on the '99?
    The stock Polaris filter is a paper and foam element, like a K&N. If its Blue with a green prefilter, is a Polaris. If its Black, its a K&N.
    Here's a pic of the filter that's on it. It looks like its a k&n but when I checked the k&n web site it says that there is no inner wire. The one that I have has an inner wire. ??? I wish I was more familiar with this type of filter but I've always used UNI.
    http://www.knfilters.com/search/prod...x?Prod=PL-1002
    toyota200x's Avatar
    toyota200x is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2003
    402
    Can we some more pics of yours wickedfinger and yours muddy200x?
    Owner of
    '98 klx 300r
    '85 250sx
    '82 185s
    Kook is offline At The Back Of The Pack Arm chair racerFirst time rider
    Aug 2003
    171
    That fox shock will fit on my '98, won't it wicked? If so, what would you want for it?
    Kook
    Washingtons Crossing, Pa.
    2,977
    Is it a concentric drive?.
    No, the shock locations are different and since theres no linkage to take up the adjustment, it won't fit. It would be nice because the 10.5" is a dual rate spring - but - it won't fit without modifications. Heres a pic or two of mine. Some of them are from before I mounted the AAEN pipe.
    Aug 2003
    171
    If that's meant for me, yes. The one I've got is spongy as hell. I've adjusted it more than half-way up and it still sits like it's riding up hill.
    2,977
    Quote Originally Posted by 250RNUT
    80 horse out of a scrambler 400. c'mon
    See for yourself .....
    http://www.hpd-inc.com/Spec5.htm
    http://www.aaenperformance.com/2S_P1.asp
    http://www.aaenperformance.com/2S_P2.asp
    http://www.aaenperformance.com/Power400.asp (chart dosent show the 470 kit though, just the 440)
    2,977
    Quote Originally Posted by Kook
    PM me about the shock ...........
    Aug 2003
    171
    PM on its' way!
    Apr 2005
    Easton, MO
    142
    Great deal you got there. My friend has the exact quad. But be careful if you go thruogh Hot Seat Performance. My friend spent $1600.00+ on a kit. He had nothing but problems from them. The race porting was nothing but an atemp to fluff and buff. Not to mention they sent the new pipe not chrome plated. They sent a new one 3 weeks later but the finish was very poor. Just a word of advice " BE Careful."
    NE. Ohio
    484
    Quote Originally Posted by Ordo
    Thanks, I'll keep that in mind. But the first thing I have to do is keep it from overheating. every time I take it out it over heats. "???" I've checked everything and still cant figure it out. It pumps good, the radiator appears to be clean, fan works, blead all the air out of the system and it still over heats. As soon as it's started it starts pissing coolant out of the overflow cap from the pressure building up. I'm guessing that the radiator is clogged up somewhere inside. I think the guy who owned it before me had well water and maybe there is calcium built up and the coolant is flowing directly across the top of the radiator. I'm starting to get frustrated. I'm running out of things to check.
    mbg75 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2003
    Long Island
    256
    nice buy!
    here is a few pics of my 70hp 4x4 scrammy.
    Back on 2 wheels for now!
    clean 86 350x for sale.
    2,977
    Again, I have to ask ... how the hell do you plow with that full race pipe?.
    Feb 2003
    Long Island
    256
    wicked,
    it plows like a bat out of hades!
    just kidding, actually it works well. the clutching helps so that the belt doesn't slip. it does not even move till about 3200 rpm, so there is no lugging on the motor. also, because of the extra weight of the 4 wheel drive, alot of the hp is wasted. the shafts are always turning.
    still surprises plenty of people out of the hole.
    we should hook up to ride, i ride in pa often. usually off I-81
    last time i went, i had it buried in a muhole past the tires. after an hour of digging i got pulled out by a grizzly.
    Apr 2005
    Easton, MO
    142
    If it's boiling over as soon as you start it, run a pressure check on the coolant system. If the pressure drops and you don't see any leaks. Your head gasket is most likely leaking. If it stays steady, back flush the radiators. Hope this helps.
  15. #30
    NE. Ohio
    484
    I bet your right about the head gasket. That would explain the unusually fast buildup of pressure. I noticed yesterday that one of the head bolts was a little wet. So, the head gasket is definitely on the "to do" list. Thanks!
