I have a mikuni 24 mm carb. I recently cleaned it and replaced the needle and the needle seat.
Now, when i run the bike, it surges up immediately, well above the idle speed, and the idle screw has no effect whatsoever on it.
The slide had this black **** on it, which I thought was **** built up, because the previous owner didnt really take care of it too well, so i took some fine emery paper and took the black coating off. Does anyone know what this is for?
All clamps and hoses are tight. I had to clean out the pilot jet really well, and used a wire to do it. Could I have damaged the pilot jet, and this be causing my problems?
It kinda sounds like an air leak somewhere, but the only thing I can think of would be the black coating on the slide, but still, where is the air coming from?
Please let me know asap, due to the bike being spart in my garage right now.
Thanks for you help,
Mike
not running yet. but won't be long.
