Results 1 to 12 of 12
Thread: Squeeling head
    dooner17 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2005
    NB
    293
    Squeeling head
    The head on my klt160 is squeeling. I took the cam chain cover off and there was plenty of oil in the head. Is there a berring on the cam that could be bad?
    Jan 2005
    NB
    293
    Anyone Please, I have no idea
    Nov 2001
    B.C.
    933
    A leaking head gasket can cause a squeal too.
    Join The Trike Registry Now!
    http://fly.to/TrikeHeaven
    Aug 2004
    Ab Canada
    4,368
    you cam chain could be too tight casing it to make a whuuuring kinda noise when it is reved up......you could also have some crap stuck in your cam journals or something too..
    1985 Tri-Z-
    Jan 2005
    NB
    293
    ok, ill losen the chain, and the head gasket isnt leaking. And it does it at idle and everything, Ill have to take the valve cover off
    Maine
    466
    Sounds like cam/cambearing. I had one do the same thing. I had to get a new cam, and a used head. $$$$
    1987 200x
    1987 Big Red
    1986 250R
    1986 Tecate
    1986 Tri-Z 250
    1986 Big Red
    1985 Polaris Scrambler
    1985 KLT 160
    1985 Tiger 250
    1985 Big Red
    1985 Big Red
    1985 250sx
    1985 70
    1985 225 DX
    1982 185s
    1983 110{Red}
    1983 110{Blue}
    (2) 1977 ATC 90
    1971 US90 Red
    1971 US90 Parrot Green
    1971 US90 Blue
    Jun 2004
    texas
    70
    it could be your head gasket. my 110 head squeeled until i changed the head gasket.
    Jan 2005
    NB
    293
    ok nothing on here sounds like a small job, this is my project bike that I paid 75$ for. I replaced the cam chain about a month ago. Is there no way to just replace the cam berrings.?
    Aug 2004
    Ab Canada
    4,368
    OH! i just thought of this........make sure the cam is pushed ALL the way into the head, or it could rub on the plate/cover infront of it if there are marks on the back of the plate/cover then you know its not far enough in.
    1985 Tri-Z-
    Jan 2005
    NB
    293
    ok what playte do * man though, the cam chain one
    Aug 2004
    Ab Canada
    4,368
    not sure on this specific bike but, do you know how to get to your cam? in the head there ther should be like a cover that covers the end of the cam with like an oil seal that screws into the head over the cam......that plate...kinda hard to explain
    1985 Tri-Z-
    Jan 2005
    NB
    293
    ok ill check it out thanks
