Results 1 to 11 of 11
Thread: Dg Pipes On 85 Tri Z!!!!
    Jan 2005
    Southeast MO.
    84
    What is the performance of a DG pipe like on a Tri Z??? And does anyone know the difference between the DG Nationals Pipe and the DG Extreme Pipe?
    Is there any difference in performance between the two or is one just nicer looking than the other?
    85 Tri Z 250
    Boyesen Power Reeds
    +4 Westcoast Swinger
    6 speed tranny
    Drag ported & polished
    Pro Lite Piston
    DG Nationals Pipe
    Too many small mods too list.............
    Power_Ram100's Avatar
    Power_Ram100 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2004
    Kent, Washington
    152
    I have the DG nationals pipe on mine i think both pipes are the same but the Extreme is nickle plated. I know i got better throttle response from mine. But i was running a CR250 pipe on it before. Thats just my .02
    I just thought of something funny...your mother
    83 Big Red with Bear Claws (SOLD)
    85 Tri Z with Maxxis Alltrax rear tires on .190 aluminum rims, DG pipe, Answer SA Pro silencer, High Flow Fuel Pump, and UNI air filter (SOLD)
    99 Yamaha Kodiak 400 4x4 with Warn winch and custom skidplates
    85 Honda 250 SX with Dirt Devils (near mint) (SOLD)
    Watertown, New York 13601
    3,382
    I have the extreme pipe and got alittle better throttle response. I wish i had gotten the Nationals pipe though. The Extreme pipe started rusting the first week!! and i didn't even use it.
    1985 YAMAHA TRI-Z 250 sold
    2006 YFZ 450
    Jan 2005
    Southeast MO.
    84
    So do these DG pipes rob the low end torgue or what? Cause thats the problem i ran into with my WORKS race pie. Are they low to mid pipes or mid to high pipe?
    85 Tri Z 250
    Boyesen Power Reeds
    6 speed tranny
    Pro Lite Piston
    DG Nationals Pipe
    Jul 2004
    Kent, Washington
    152
    Well DK says: Both pipes Pull harder from mid-range to top end.
    http://www.denniskirk.com/jsp/produc...Id=&leafCatId=
    Aug 2004
    Ab Canada
    4,368
    The DG pipes are basicly a stock replacement for the tri-z they help a little but wont rob any power from the bottem end-there like a stock pipe like where the power is..
    1985 Tri-Z-
    Mar 2004
    North Central Ohio!!
    2,712
    Quote Originally Posted by My trike Sucks
    I'm not sure whether I agree with this or not. When I installed my DG extreme, I noticed that the bike didn't want to wheelie near as easy down low like it did with the stock pipe. The power band definately changed. I couldn't say whether it actually lost low-end or if it just hits so much harder in the mid-range now.
    It really made the bike alot harder to trail ride, because the low-end just doesn't seem to be there.
    RichinMO's Avatar
    RichinMO is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2002
    Waynesville, MO
    321
    SEMO, where are you at in Missouri?
    1985 ATC250ES
    1985 ATC250SX
    1984 ATC200S "Little Red" - Trailer hitch, Hondaline: Front and Rear Racks, Cooler Rack, Tripmeter, HL Grille, Rubber Footpeg Covers, Mudflaps.
    1985 ATC70
    2008 CRF230L - Dual Sport
    2016 TRX500 Foreman Rubicon Deluxe
    Rittman, Ohio
    6,276
    Most DG pipes are pretty much stock replacements. On the TriZ, mine gave me a little more bottom end than stock, (nothing extraordinary) but I saw no noticeable difference in the rest of the powerband. I also saw no difference in jetting requirements from stock.
    Nov 2004
    Waterloo IL
    2,701
    DG sucks. I took the DG off my 250R and put on an ESR. Wow, that was the biggest difference from just exhaust I have ever seen. Way more change than going from stock exhaust to a Yoshimura full system on my 450R.
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    03 400EX- XR650R engine
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86,86,86,86,86 Scrambler
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    84,84,84,84,83,82,80,79 ATC70
    82,79 XL500R
    83 ALT50
    79,78,77,77,76 XT/TT500
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72,71,70,70,70,70,70 CT70H
    72 SL100
    70,69 Z50
    Washingtons Crossing, Pa.
    2,977
    When I switched from stock to the DG extreme on my '86 Z, I noticed quite a bit more top end power but no real noticable loss in bottom end. Did it give it more Horsepower or was it just a shifting of the powerband "north"?. I would have to say yes to both. I had no problem pulling wheelies - but - the jug was also ported and had most of the wrench report mods done as well.
