I have looked at my manual and parts fish and need some clarification. I am working on a 1983 CDI ATC 110. I just had a valve job done and had the cylinder honed. I purchased a new "top end" gasket set and am getting ready to put it all back together. Besides the gasket that fits over all 4 case studs and seals the area between the case and the bottom of the cylinder is there any other o-rings that go there. I see where an o-ring goes on the top of the cylinder in between the head and cylinder, but I'm not sure about whats on the bottom of the cylinder. I do have my 2 dowel pins that are lining up, and the above mentioned gasket, but is that all I need in this area?
Also why does only 1 stud on the top of the cylinder get an o-ring? Why don't all 4 studs get an o-ring?
Thanks in advance for your help! S.
