Results 1 to 12 of 12
Thread: 3 wheel drive
    Bender is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jun 2004
    Chippewa Falls WI.
    234
    3 wheel drive
    I thought of this last night before i went to bed. I was thinking about building a go cart with a 8 horse briggs lawn mower engine that i have laying around, well i got a better idea. Weld a mount for the engine on the front forks, somehow get a sprocket to mount on the front rim. I dont think that it would be that hard, i thought it was a good idea. Has any done this (im sure someone has). I would do this to a big red or some thing, it would be kinda hard to put on my 200x forks.
    86 ATC 350X
    86 ATC 200x (my P.O.S.)
    ATC 70 (first trike,7 years old)
    Email: Bender@bodybuilders.com
    SE Minnesota
    533
    rokon
    check out the rokon bikes, they are 2 wheel drive
    83 YT 175
    85 ALT 125
    Aug 2004
    PA
    190
    I don't know about other trikes, but having the front wheel drive on both my trikes would be worthless because there is hardly any weight up there.
    Apr 2005
    northern MN
    69
    Im not sure but you might have problems with control of the power in the front wheel vs the back if one spins faster then the other you might start to snap things , or draging the rear wheels. I dont think its an easy as it sounds fab job,but would be cool.as long as the chain dosnt some off and take your head with it.good luck w/ it hope it works out for you if you try.
    Mar 2003
    Barnesville,Ohio
    2,298
    hydrolic motor to the front or use rokon's idea. i would just take a rokon and turn it into a trike
    1985 Honda 350X - a lot of performance stuff, everything but a cam, hope to get one soon
    1984 Honda 200ES
    198? Yamaha YT60 Tri-Zinger
    TrikeFest '04 & '07 Survivor
    Jun 2004
    Chippewa Falls WI.
    234
    I would only use it in the mud so the back tires would be spinning so how fast the back and front are moving wouldnt relly matter and know that i think of it, it wouldnt help much any way cause of no weight in the front. but i more or less want to do it just to say i did it.
    86 ATC 350X
    Jun 2003
    South of Rochester, NY
    3,471
    It seems like Dirt Wheels did some kind of experimental trike like that, or at least had a pic in "Over the Bars"... I'm guessing 83-ish?? I remember seeing it and thinking it was
    Bruce
    '86 ATC350X - 'Go-Go Girl'
    '85 ATC70 - All Original
    '83 Suzuki ALT125 - Pieces
    Jun 2004
    Chippewa Falls WI.
    234
    i just did a search on rokon and they do make a trike
    its in the upper right hand corner
    http://www.rokonworld.com/start.html
    86 ATC 350X
    May 2002
    Southeastern Wisconsin
    3,658
    Those Rokons always make me luagh. I'm pretty sure they don't make a trike anymore.
    Mar 2003
    Barnesville,Ohio
    2,298
    thats not really a trike...its more of a rokon with a sidecar. its only 2wd too. i dont think they ever made a 3 wheeler
    1984 Honda 200ES
    atczack's Avatar
    atczack is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2004
    Fort White, Fl.
    423
    There used to be a site called rokonfreaks and it had a 2wd rokon that somebody made into a 3wd trike. It was sick. It looked like it would go through any mud hole you threw it at. I just tried to look it up but the page wouldn't come up.
    1985 Honda ATC 250 Big Red
    "Ugly Betty" from the handlebars back it's a
    1982 Honda ATC200es, from the handlebars
    forward it's a 1988 Honda TRX 300 Fourtrax.
    "If you wanna play, you gotta pay..."
    Jul 2004
    minnesota
    689
    go into BIKERSVILLE and take a look at my rokon pics i have in there, when it cleans up it looks almost brand new.
    my trikes:
    1983 honda atc 200x-k&n filter
    2002 yamaha raptor 660r, yoshimura slip on, prm grab bars
    1978 chevy nova, 454 v8, bds blower, 150hp shot of nitrous, full roll cage, a real power house.
    1991 chevy s10 4x4 350v8.
    1986 250sx
    YES its fast NO you cant ride it.
