my tire size is 22x12x9, my question is can i get a taller tire, say a 24x12x9 to fit on the 12x9 rim or does it have to be 22?? does the 22 matter in getting a new tire to fit the rim, or is it just tire height??
1983 Honda ATC 200x-shes a beater
Past Rides:
1982 ATC Big Red 200e (miss it more than i thought i would)
1985 200x rode it for about a mile
also will it help provide suspension for riding?
Past Rides:
The 22 is the tire height.
The 12" is the wheel diameter.
The 9" is the wheel width.
You can go as tall as you want so long as it fits a 12" dia. rim and 9" width.
Check with the tire manufacturer just to make sure they recommend your particular rim width with the tire you're looking at.
If it's a mega-ply heavy duty tire, it'll ride rough with a hard sidewall.Originally Posted by Oldshell4481
If it's a softer sidewall (less durable) tire, it'll be sweeeeet.
My old Polaris Explorer had TALL and wide stock tires and they rode GREAT.
That thing was like riding a couch through the trails.![]()
yeah i dont know what tire i want, but i cant find many good tires in 22x12x9, any recommendations for mostly mud/dirt road/trail riding??
Past Rides:
Originally Posted by MO350X
You got the diameter and width backwards.... the last number is the diameter. Make sure your height difference wont interfere with steering or your rear fenders! The rear tires on my Yamahauler are 25x13x9... seems like just the inch wider than stock made them taller too, and I have a hard time getting the fenders on and off it.
Bruce
'86 ATC350X - 'Go-Go Girl'
'85 ATC70 - All Original
'83 Suzuki ALT125 - Pieces
I thought he was talking about a utility quad wheel?
They're 12" diameter if I'm not mistaken.
Is there such thing as a 9" dia. wheel with a 12" width?
That'd be a beast!![]()
I'm picturing the baddest Holeshot width footprint in the universe!![]()
22 is the the diameter of the tire
12 is the width of the tire
9 is the diameter of the rim
I have 22x12x8 on my 250sx . I don't know if you can get a 24 inch tire but there are 25 inch tires out there that will work on the rims. A bigger tire like that might rub on fenders and it will decrease your aceleration. I would stick with the 22 inch tire if it was my trike. Let us know what you do.
Owner of
'98 klx 300r
'85 250sx
'82 185s
yeah, its just trying to find a good mud tire that will give some good suspension as well, my knobbys do great, but too much road riding wore them down.
Past Rides:
If your going to be buying tires soon, I would reccomend www.rockymountainatv.com cheapest place I have seen
I've also heard Rocky Mountain ATV is fast and inexpensive.
Not too many ATV tires fare well on asphalt anyway.
You can replace a couple (or more) knobbies for the price of some higher-end tires.
Sorry about the confusion on the tire/wheel sizing.
I didn't realize what machine we were talking about.
Heck, our beloved Big Red's came with 25" tall tires.![]()
You'll be changing your gearing to a taller ratio too. Depending on your type of riding that may be good, it may be bad.
You'll lose some low end grunt, how much I couldn't say.
Ahuh.... 25 12x9 was standard on.....
80-83 ATC185, ATC200 81-83, 82-87 Big Reds, YTM200E 83-84, and the YTM200ERN 85 oh.. and the KLT250A 82-83.
Those would be the 3 wheeled applications... from page 736, ATV Spec Chart in Dennis Kirk..
Bruce
Or as we like to call, the height... I've never refered to this as diameter before, cause normally when you are talking tires, the diameter refers to the inside "hole" for the rim. The other is the height, so you don't have to refer to inside diameter and outside diameter.Originally Posted by toyota200x
Bruce
Be aware of PIPE clearance.......
My big red had carlisle(sp)'s on it and it rubbed the exhaust bad.
my SX now has 22x12x8's and they also rub the pipe a tad.... got the shock on the lowest setting for my weight..
Currently :
84 125 M - The Mini-SXnot running yet. but won't be long.
