Results 1 to 15 of 18
Thread: 125m starts but runs wide open HELP!!!
    I just got a 1984 125m today i traded a pocketbike for it,heres the problem the bike starts right up first try but revs to the moon when started the throttle isnt stuck,any ideas of what the problem could be?
    Bike sat for a year without being started and i added gas and gave it 3 pulls and it fired right up but reved so high i thought she was gonna blow up.
    Its in pretty good shape the tank dosent have a spot of rust in it and its never been treated only real problems with it are its missing a headlight the rear tire has a slow leak and the sub trans is busted
    heres a few pics of it
    1983 Honda 110
    1967 Mustang
    Jan 2005
    Spruce Head Island, Maine
    893
    did you check the idle?
    1983 Honda ATC 200x-shes a beater
    Past Rides:
    1982 ATC Big Red 200e (miss it more than i thought i would)
    1985 200x rode it for about a mile
    I havent really messed with it yet just added some gas and wanted to see if it started,the bike starts normal but then the rpms start climbing up i was wondering if maybe the carb being dirty could do it?
    1983 Honda 110
    1967 Mustang
    Jan 2005
    893
    maybe, if something is stuck in there, wouldnt hurt to clean it anyway.
    Past Rides:
    Jan 2005
    893
    nice score on the trike by the way
    Past Rides:
    Washingtons Crossing, Pa.
    2,977
    Throttle slide might be in backwards .... been there, done that. Otherwise - a really bad intake leak.
    Dave223 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2004
    Houma Louisiana
    388
    hey, same thing happened to me once to, the throttle slide is in backwards, heres the fix: unscrew the cap on top the carb, where the throttle cable goes in. Pull out the slide and the needle. Now on the slide are 2 grooves, a wide short one and a narrow long one. The wide short side goes on the same side as the idle set screw. or, to make a long story short, pull the slide an turn it 180, put it back in.
    Thanks guys
    1983 Honda 110
    1967 Mustang
    Well tonight i messed around a lil bit with the bike and cant get it to stop reving to the moon i tried taking the slide out and spinning it, i tried adjusting the carb nothing seems to help no matter were i adjust the screws on the side of the carb it revs to the moon,its very weird because no matter how i adjust both screws the bike starts right up one pull.
    any other ideas or input would be apprciated thanks.
    could all the wiring where the headlight be have something to do with it,theres a few wires that arent connected to anything and the key is by passed
    1983 Honda 110
    1967 Mustang
    Jun 2004
    Brazil, Indiana
    1,389
    when * put the slide in did it go al the way down or stay just a little over the top of the carb?? if its a little over the top then its still wrong..it should slide in and go down quite a bit
    trikes owned:
    85' 200m - sold
    84' 200x - sold
    83' 185s - sold
    82' 185s - sold
    85' 350x !!! - selling
    Jun 2003
    South of Rochester, NY
    3,470
    Hey... thanks for the pic! Now I know what that dash I have came off from! You need one of those HONDA dash pads? I might have one here.... I know I got a 84 125M headlight and shell.... let me know if you are needing one. If you take some good pics of the carb, I might have that here too. I basically got a complete parts 125M here except plastics, wheels, subtranney.
    Did you observe the operation of the slider? Did you have the air filter and hose to the air box connected to the carb when you are starting it??? We (theolderfox and I) were trouble shooting my 225DX, and started it with the carb not attached to the airbox and it reved up to high heavens... regulated the rush of air a bit by covering the carb intake over partially with a hand and it reved back down some..... make sure thae air box, air filter and such are a go before mesing with carb adjustments...
    '86 ATC350X - 'Go-Go Girl'
    '85 ATC70 - All Original
    '83 Suzuki ALT125 - Pieces
    Aug 2004
    Ab Canada
    4,368
    Air Leak
    1985 Tri-Z-
    faf_racing's Avatar
    faf_racing is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jan 2005
    pensacola florida
    187
    Lightbulb
    throttle cable?? its been sittin for a year, maybe has some rust or dirt keeping the cable from moving freely. if the slide is in correct and intake tube isnt cracked. spray pb blaster down the cable and work it too seeif that helps. (motor off) of course! makes sense too me good luck! also see if the cable isn't creased or pinched somewhere causing the slide not too "slide" all the way down
    Apr 2005
    uk
    4
    same thing happened when i got my 84 125m, i tried everything. in the end it turned out to be a very slightly bent needle
    Thanks for the ideas i got somemore trouble shooting to do today
    1983 Honda 110
    1967 Mustang
