Results 1 to 15 of 15
Thread: 200x for $400 but has problems, good deal or no?
    benscool1 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Williamsfield, IL
    226
    I am looking at buying a 84' 200x for $400. It is supposed to be in really good condition except for the fact that the cam is locked up and the timing chain is broken. Is this someething that is easy to fix, even for a novice? How much would it cost to fix? I have seen another one for $250 with something wrong with the crank? I need your opinions. Help me. Email me @benscool1@hotmail.com.
    Dec 2002
    Kansas
    2,387
    I was told that this trike was only worth around the $400.00 range if that helps any. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=6724&item=24016025 62&rd=1
    Williamsfield, IL
    226
    Somebody must know something about this.
    85200xer is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2002
    194
    to get to the cam you must take the motor out of the bike. then to replace the camchain you will need a flywheel puller. It is really easy if you watch where all of the parts you take out go I paid 600 for mine and it didn't need any work except a 15.00 set of axel bearings. I have a book and a scanner so if you need any help Just pm me. I wont be around from this coming wednesday to monday. I'm goin' to revelstoke :o
    just remember you aint gonna learn if ya don't try :x
    later,
    85200xer
    85 200x, powroll 12:1 comp , race cam, barnett clutch,supertrapp exhaust, 350x suspension.
    01 800 summit, 159x2 track, dual pipes, reeds ready for snow.
    www.geocities.com/bjh200x/PHAT_TRIKES.html
    :Beerchug
    I wouldnt pay over $325 for an 83-85 that needs internal work like that.
    GOod luck,
    Rob
    Howdy's Avatar
    Celina, Ohio
    10,079
    I'm with ATCRyder here. I would shoot more for the $250-$325 range. If the cam is bad most likely it will need a head also. The cam will wear grooves in the head. Luckily I have some spare parts for when I buy machines like this one. It pays to save stuff. lol
    Levithan is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Puget Sound, Washington
    319
    I got my 200x for 200 bucks, and it had some problems. Here's all the problems: Cracked headlight and broken bulb, axle needed new bearings, and also needed to be repaired because the last person who had it rode it on bad bearings, which chewed up the axle; Bad CDI, no light switch, broken airbox, bad rear caliper, and the swingarm needed to be reparied. Heh, i was desparate enough to buy it, but its almost fixed now, which is pretty cool. Hope you find one thats good to ya!
    Dec 2002
    72
    200x
    I guess I would ask what does "locked up" mean? If you lose the cam gear you may be able to replace that, however, if you lose the cam (seized, broke, or other) you will want to replace the head. It depends on the cam journals, rockers, and lobes. I woule be careful paying $400 for something like this. My max would be around $300. You should replace the cam and bearings at one time and possibly the rockers which are worn to the old cam lobes. Might create an issue.
    Good Luck,
    Mike in Michigan
    (2)84 200X
    84 200X (restoring)
    82 250R (restoring)
    86 250R (New Baby)
    Williamsfield, IL
    226
    Thansk for the help guys. But now what about the one with the messed up crank? I'm trying to figure out which one is the best deal, and if anyone knows that they can get me the parts that you guys say I need if I do get these and live fairly close to Illinois it would help.
    How bout that crank? harder to fix or easier? Its $250
    76' ATC90
    200xer is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    I would spend the money and get one that is already running and only needs things like brake pads or tires or bearings. I bought a 200x that had motor problems and it can be a nightmare.
    Crank problems (depending what that means) can involve splitting the cases. Which really isn't too bad, but a lot more work that doing the top end.
    85 200x - Torn apart
    PLJ. is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2003
    253
    I believe that this is one of my listings that you are refering to. I do not have a ton of intimate knowledge of it, since I am selling it for a friend. But here is what I know. My cousin bought this 200X brand new in 84 and never put much time on it. It passed through a few sets of hands over the years and ended up in my friends garage. I never knew he even had it!! He called me up a while ago looking for advice on how to replace a timing chain. I went over to look at it and he had the top end removed. The cam froze itself to one of the bushing that aligns it in the head, this stoppage then broke the timing chain. The piston, bore, rod and crank all appear unhurt. Before disassembly. he drained the oil and noticed that it was diluted with gas, he flooded it terribly, which may have caused all the problems. He purchased a new chain and gaskets but never put it together. I said that I may be able to sell it for him. Very nice condition. Excellent tank, plastic, fenders, bearings, lights, tires, chain and sprockets, cases and controls. I sold one last spring with a locked up crank for $350.00 I was hoping to get him $400.00 for this one. What do you think?? Thanks.
    Williamsfield, IL
    226
    Thats a lot more detail then i had before. Thanks. So it has all the parts it needs to be fixed?
    76' ATC90
    Feb 2003
    253
    I believe that he has a gasket kit, new timing chain and new cam alignment bushings. I will check with him for a complete detail of what he has. I apoligize if I was short with you before, I have been running in circles with people who do not have any clue about what they are looking at or inquiring about on my adds. You sound different. Let me get you a few pics and a list of what parts he has purchased. Thanks.
    Williamsfield, IL
    226
    Ok, thanks a lot man. You said no trades in the email right?
    76' ATC90
    Feb 2003
    253
    Yes, that right. Cash or money order only. Thanks.
