I found out the axle on my 86 R is shot since the bearing surface has been worn down too much allowing quite a bit of slop between the bearing and axle surface. I've been looking around at the different axles and was thinking about going with the durablue eliminator axle. Anyone have experience with one? Does it come with the locking nuts or do you use the stock unit?
