Results 1 to 2 of 2
Thread: paint 250sx differential?
    Jan 2005
    Jones, Michigan
    1,821
    Well i'm going to get bearings tomorrow for the entire machine and so i'm real anxious to put it all back together. I only have one problem and that is with the differential. The paint is almost all flaked/worn off of it so i'm going to sandblast it. I'm replacing the 2 bearings for the axle but the pinion gear bearing or whatever is in excellent condition so i'm not replacing that one. The axle bearings werent in horrible shape but i figured i'd change them before they did get bad. what i want to know is if i should paint, powdercoat, or leave the differential bare metal? It's aluminum so it wont rust but will it look like crap if i leave it bare? Is there something i can do to prevent the aluminum from oxidizing? Is there any paint that will hold up and is someone cheap? I think powdercoat is out of the question because i would have to pull the pinion gear and bearings out or else they would get damaged. I just cant decide if i should leave it bare or paint it or go to the bother of pulling the pinion gear and bearings out to powdercoat it.
    thanks
    Kevin
    - Chick McGee
    -1985 250sx
    - 1986 atc310R drag bike
    - 1981 110 chopper.
    - 1985/6 350x
    - 2-84 atc250r's and 1 83
    - 2002 trx400ex
    - 1985 atc 250r
    -1985 atc70 WTB PARTS
    - 1985 tecate
    Mar 2003
    Australia
    1,919
    Just paint it with some automotive paint. I did mine and its held up fine so far. And it looks new.
    Matt
    1980 ATC 70 Needs Restoration
    1985 ATC 250es Fully Refurbed
    1986 ATC 350x Mint Original
