Results 1 to 15 of 26
Thread: What do you use to clean drive chains?
    Opelousas, Louisiana
    1,337
    I finally got some good lube and need to clean a non and a oring chain.
    What should i use to clean them?
    1986 350X K&N filter, DG Krome Power exhaust
    1982 110 UNI filter, Cobra megaphone exhaust
    1982 honda 110 exhaust for sale, PM me.
    Jul 2004
    Mud hill. close to water !
    3,658
    is it currently ON the machine of off ?
    if it's off.. dip it in gas and shake it around good.. then let it hang dry.. and lube it up.
    if it's on..... welll... i'll let someone else chime in on that.
    Currently :
    1,337
    its on but i can take it off. the manual says to use kerosene.
    Mar 2004
    Eastvale, CA
    630
    Quote Originally Posted by bigredhead
    Dipping or soaking the non o-ring chain in gas is fine but don't use gas on the o-ring chain as the o-rings will react and expand and the chain will be ruined. Don't use a wire brush on the o-rings either as that'll cut them up and ruin them too.
    Current Ride (Purchased new in Oct. 84) - 1985 Honda ATC 250R w/ ESR 310cc big bore kit
    Wife's Ride - 2009 Polaris RZR 800
    Kid's Rides - 2009 Yamaha Raptor 700, 2008 Yamaha Raptor 250
    Former Rides - 1975 Honda XR 75, 1979 Yamaha IT 175, 1978 Honda ATC 90, 1980 Honda ATC 110
    got sand?
    1,337
    well then what do you ^^^ use to clean it?
    RichinMO's Avatar
    RichinMO is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2002
    Waynesville, MO
    321
    O-ring on bike: parts washing brush and kerosene
    1985 ATC250ES
    1985 ATC250SX
    1984 ATC200S "Little Red" - Trailer hitch, Hondaline: Front and Rear Racks, Cooler Rack, Tripmeter, HL Grille, Rubber Footpeg Covers, Mudflaps.
    1985 ATC70
    2008 CRF230L - Dual Sport
    2016 TRX500 Foreman Rubicon Deluxe
    May 2003
    So. Cal.
    85
    I put some old pre-mixed gas in an old ~2 gallon liquid laundry detergent jug (that's been washed out good) and drop the chain in there and shake it around real good, then take it out, pour some of the gas into an oil pan and scrub the chain real good with a parts brush, then back into the jug and shake it around again to rinse off any sand clinging to it and hang it out to dry. My chains are non-o-ring, but I used to do that with my old o-ring chain too untill I got a new one. Nothing happened to the o-rings and I cleaned it that way quite often for about 2 years.
    Pa.'s Highest City
    8,058
    Which ones are better? O or no O?
    Mar 2003
    Barnesville,Ohio
    2,298
    x-ring is best, then o-ring, then non o-ring. i just spray down my whole bike with super clean, leave it set a few minutes, then pressure wash it all off, it works good on the chain and everything
    1985 Honda 350X - a lot of performance stuff, everything but a cam, hope to get one soon
    1984 Honda 200ES
    198? Yamaha YT60 Tri-Zinger
    TrikeFest '04 & '07 Survivor
    1,337
    whats super clean?
    Mar 2004
    Newnan, GA / Near Atlanta
    1,727
    The purple stuff you buy at the parts store. Kind of a degreaser. AutoZone has it. Thats what I use. That and Bleech White. Gas will definately make the o-rings swell up. If you ride it while they are swollen, they will be toast. The swelling will usually subside a bit, but they will never be the same. Just use the purple stuff or bleech white and a plastic brissle brush. It will get it all off for the most part.
    Clay Whitman
    Newnan, GA
    AMSOIL DEALER
    My Toys
    2008 Yamaha Rhino 700 SE
    sandrooster is offline At The Back Of The Pack Arm chair racerFirst time rider
    mom's house
    193
    I've been using pump gas to clean my O-ring chains for twenty years on all my trikes.
    I remove the chain and clean after every ride. Still using the original stock chains. Never had a problem, no cracks on any O-ring. Of course I use good chain lube after I wipe and hang dry.
    85 ATC250R
    Jan 2005
    Albany OR
    15
    Use a chain scrubber........ Here is one link I found
    http://www.powersportsnetwork.com/ac...ries104502.htm
    85 ATC110 - restored then sold to buy 350X
    83 ATC185S - restored/sold to pay for 350X rebuild
    85 ATC350X
    1,337
    the owners manual recommends kerosene so you think it would be ok to use diesel?
    asc180's Avatar
    asc180 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2002
    Howard City, MI
    209
    I use kerosene for my chains. Diesel will work fine.
    Adam
    89 LT500R-
    85 250R- Project-
    85 250sx-
    83 185s
    80 act70
