Page 2 of 2 FirstFirst 1 2
Results 16 to 26 of 26
Thread: What do you use to clean drive chains?
    Opelousas, Louisiana
    1,337
    all i got to say is never use gear oil on a chain as lube. i used diesel and it was soooo dirty One more question: how long do i need to let it dry before i put some lube? (Klotz KLR)
    1986 350X K&N filter, DG Krome Power exhaust
    1982 110 UNI filter, Cobra megaphone exhaust
    1982 honda 110 exhaust for sale, PM me.
    Mar 2003
    Australia
    1,919
    I have a mate who cleans his chain off first with kerosene. He then heats up oil in a pan and "cooks" the chain for a few minutes. It really does work and the chain looks new! Just dont spill the hot oil onto yourself, that could hurt! Oh, and i doubt this method would be suitable for an O-ring type chain.
    Matt
    1980 ATC 70 Needs Restoration
    1985 ATC 250es Fully Refurbed
    1986 ATC 350x Mint Original
    Las Vegas, NV.
    2,538
    Quote Originally Posted by Mr. Sandman
    Dipping or soaking the non o-ring chain in gas is fine but don't use gas on the o-ring chain as the o-rings will react and expand and the chain will be ruined.
    I've used gas to clean O-ring chains for years with no damage to the O-rings, but lately I use solvent, just because it's a lot safer to work with than gasoline. Mr. Sandman, it was the carburetor cleaner/parts dip that destroyed the O-rings in my ATC 110 chain, not gas. I think you may be confusing the two.
    Jan 2005
    Slatington PA
    4,372
    Kerosene or diesel is the hot set up.
    Always WD-40 the chain immeadiatly after a wash as it keeps the chain from rusting.
    Oring and Xring are the only ones I'd use but then again all mine are shaft drive so I'd use none of them.
    What kind of lube did you buy? Some lubes actually attract the dirt and to me are worse then using none at all.
    .........and last, which way are you putting the master link clip on?
    Jan 2005
    Slatington PA
    4,372
    Quote Originally Posted by Red Rider
    Yep, it's a good habit to get away from using gas as a cleaner for safety reasons. I used to use it myself but got away from the habit years ago.
    Jan 2005
    Spruce Head Island, Maine
    893
    i think they reccommend a "high flash solvent" to make it a little safer.. you can put a match out in a bucket of diesel, i dont know about kerosene but it is very similar to diesel..
    gas is another story, i would never use gas to soak anything in, as leaving gas laying around in a pan is a hazard in itself.
    1983 Honda ATC 200x-shes a beater
    Past Rides:
    1982 ATC Big Red 200e (miss it more than i thought i would)
    1985 200x rode it for about a mile
    1,337
    kerosone/diesel works real good.
    Jul 2004
    Mud hill. close to water !
    3,658
    Quote Originally Posted by BIGCRIP28
    But it reeks !
    How bout a pressure washer ( 1300 psi ) at a 4 inch distance !!!!.. blast it clean and then re-oil. don't even need to remove it from the bike !!!
    Currently :
    Roanoke, VA
    4,038
    I've always taken a hose or pressure washer to my chains (Non O-Ring) to clean them. Immediatly after, spray the chain with WD40 and let it dry. After that, use what ever you want to lube it....except for grease or wax...they will attract dirt and hold it to you chain
    [20:55] <waterpumper> putting a racing pipe on a Foreman is like putting a high dollar bikini on a 400 pound chick...just because it fits doesn't mean it looks cool
    crackshot's Avatar
    crackshot is offline Worthless, would be a vast improvement. Arm chair racerJust too addicted
    Idaho
    1,024
    I know an old racing secret for chain grime and used it for years. Melts the crap right off and in the chain area where the small spocket off in the case.
    It does not stink, will not harm plastic of rubber and blasts off with garden hose.
    Can't tell you what it is because its a secret!
    1,337
    Quote Originally Posted by crackshot
    thanks for sharing.....
    a..hole.
