Tecate carb question
Ok on my tecate when you start it with the choke on, it runs fine but shut it off and away she revs. So I took off the carb today and was looking at the choke slide thing. It has a hole in it and the carb body has a hole in it. When the choke is off these two holes should line up correct? And when the choke is on the hole should be blocked correct? Well on mine when the choke is "on" the holes line up and she runs fine but when the choke is "off" she revs up and kind of sputters and stuff. So is my choke backwards somehow? I don;t know as I have never messed with the carb other than spraying some carb clen in it. Thnaks
Cody
//ArrowChat Integreation Code
