Thread: 81 VS 82 250R Front Brake Caplier
    Riverview, New Brunswick, Canada
    83
    G'day guys, I was just wondering if a 82 Front brake caplier will work on an 81 250R? If not do I just need the larger front disk that the 82 250R uses?
    Thanks
    Adam
    81 250r Stocked
    85 250sx Stocked "SOLD "
    99 400 Polaris Scrambler 4X4
    91 Yamaha Phaser II
    Jun 2003
    South of Rochester, NY
    3,471
    Quote Originally Posted by Adam250sx
    Thanks
    Adam
    Hmmmm.... pretty sure the front calipars are the same, only difference was the 82R rotor was a drilled rotor while the 81R was a solid disk..... any one else????
    Bruce
    '86 ATC350X - 'Go-Go Girl'
    '85 ATC70 - All Original
    '83 Suzuki ALT125 - Pieces
    I may be wrong but the older "R" calipers look identical to the 83-85 200X calipers.
    Jan 2005
    Great Bend
    704
    the front caliper for the 81-84 ATC250R and 83-85 200X's, maybe 86-87 200X's but I'm not sure, were all the same.
    Jun 2003
    3,471
    The calipar themselves might be the same, but the mounting brackets are different. Either case, the answer to 81 vs 82 we can agree that they are identical!
    Bruce
    83
    Thanks Guys appericated it!
    81 250r Stocked
    91 Yamaha Phaser II
