Results 1 to 3 of 3
Thread: Timming marks on 86 200x?
    Maryland
    3,077
    I'm scrambling to do the top end on my 86 200x before I take my trip to florida to visit Lonesometriz and I need a lil info about setting the cam & timming back up. I know I should just get a manual but I don't really have time at this point.
    I've searched for 200x timming info on the board but everything is about the 85's and not the 86s. Any help with setting up the markings would be appriciated. I'm assuming to start with the T on the flywheel (acutally i haven't looked at the flywheel yet just kinda assuming) but I'm not sure where the markings on the cam sprocket line up and also there appears to be some kinda of arrow indicator on the opposite side of the cam. I should have paid more attention taking it all apart but as I said I've kinda been in a hurry. (the machine shops gonna hurt me bad for the rush I'm sure. lol)
    Any info/advice on setting the timing back up would be appriciated.
    Thanks.
    Feb 2005
    Tennessee
    44
    200X Timing
    The way I did this was to get the piston at the top and make sure the mark on the flywheel is between T and F. There are two lines on the cam, they should point sideways in the motor. This would make the arrow on the opposite end of the cam point up and down. This is the part I am trying to remember. I am not sure if it goes up or down. Check the intake lope because it should be the first valve to open. I hope this helps.
    Trikes owned:
    1987 Honda 200X
    1986 Honda 200X
    1985 Honda 200X
    1985 Yamaha 200
    oddball3's Avatar
    oddball3 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2004
    New Jersey
    224
    start with the T mark on the flywheel, I believe the arrow mark should face forward (the front of the engine). the line of the arrow and the line opposite the arrow should be paralel with the top of the head.
    Will try to find the manual and double check tommorow.
    IN MY GARAGE:
    1984 250r
    1986 350x
    1986 200x(wifes)
    1985 200x fixer upper
    1979 110 PARTING OUT
    1984 70
    http://www.hardcoresledder.com/forum...post&id=155447
    '97 ZRT 600 drag sled
    '97 ZRT 600 trail sled
    '98 ZR 440 sno-pro(wifes)
    http://www.hardcoresledder.com/forum...=post&id=79401
