Thread: 85 250R with no Spark!!!!
    Apr 2004
    PA
    4
    I really need help. My 85 250r won't start and i have no spark. Over the last year I bought a brand new stator, 3 different CDI's a new iginiton coil. One Honda dealer told me it's the CDI and another one said their good but no one can figure it out. I've gone over the wiring harness wire by wire and all of the switches about 10 times and everything seems to have good continutiy. Before the bike died i had a very weak spark but it ran rough. Does anyone have any idea what i'm missing.
    Any help would be greatly appreciated
    Darren
    wanta86r's Avatar
    wanta86r is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2004
    mn
    385
    i had it happen to me- it ender up being a short in the on / off switch
    Mar 2005
    S.C california
    had similar problem caused by incorrect gap in spark plug
    Jun 2004
    potsdam ny
    1,227
    hmmmm, how is your pick-up? did a case bolt ever come out in there while it was running and get slammed around hitting the pick up? i would change your pick up if you havent already done so and everything else is new as you said....
    Jul 2004
    spokane wa.
    19
    just a long shot. is the flywheel free spinning on the crank shaft cause the woodruff key is broke or gone. had this happen to me once, with a no spark problem. good luck!
