Results 1 to 8 of 8
Thread: How do you take the forks out?
    springville, PA
    6,185
    The other weekend I was taking my tire off the front of my SX and the only way to do it was to take most of the air out and squeez it by the right fork (if your sitting on it). So I though to myself why dont you take that fork off and just take the tire off that much easier. Well i took all the bolts off and with a rubber I was pounding away at the top of the fork. I even spread the trees a little to help take pressure off the fork. Shouldn't it just slide right out or is there a secret I dont know?
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    Nov 2004
    Fort Kent, Maine
    2,132
    You took all 8 of the bolts out right? (on both sides)
    Oviously the front end must be off the ground.
    If you did all those things, try putting some lubercant in between the forks and triple clamps then hit them.
    '85 350X-The Flagship
    Speedo, Chrome HL Guard, Rubber Steps
    DG Chrome Power, 6-Pack Rack, White Bros Skidplate, 400ex Carb
    '85 250ES Big Red-Working in Style
    Many Hondaline & Aftermarket Add-ons
    '84 250R-Old School Racer Project
    Too many Accessories to List
    '82 200E Big Red-The Tractor
    Rubber Steps, Tripmeter
    '85 250SX-Rider
    Various Accessories
    '13 CBR250R & '05 CBR600F4i-Road Toys
    Yoshi Slip-Ons & Fender Eliminators
    Jan 2005
    Great Bend
    704
    this is extensive but wrap a shop rag around the fork leg thats in between the tripple clamps, use a pipe wrench and slower apply pressure to make it turn, if it starts to turn grab the fork below the tripple clamps and pull down at the same time. doing this should make the forks come out
    Mar 2004
    Newnan, GA / Near Atlanta
    1,727
    I have also used a big fat dull chisel to slightly seperate the tree where it clamps dows. I put it in the crack and tap it a couple times, then they are loose. Doesnt hurt anything.
    Clay Whitman
    Newnan, GA
    AMSOIL DEALER
    My Toys
    2008 Yamaha Rhino 700 SE
    Mar 2004
    Gettysburg PA
    498
    Quote Originally Posted by ClayW
    yeah thats what i usauly do is get a fat chisel or a screwdriver and pry them open a little bit and tap them out it usualy works pretty easy
    My Trikes
    1985 250sx
    1986 250r
    Parting out 85 kxt tecate pm me with your needs
    springville, PA
    6,185
    I used the screw driver before to help separate the forks but I was in a rush so I didnt apply lubricant. Ill try the turn and pull method if lubricating doesnt help. Thanks Everyone
    Nate
    R.I.P HRR
    Mar 2005
    overton, PA
    5,257
    i shut the gas off stand it up on the grab bar, unbolt the axle the oen with the 4 lil nuts, and take off the little cap, then use one of thise strap wrenches from sears, thier liek aplastic handle with a rubber strap, know what i mean, but if its fogot a cap on th etop with a place for a socket or wrench, i turn it as if i wer etightening and leave the socket on it and give it a little tapity tap with the ol , but i watch out and make sure it stayes on there cause * dont wanna mes sup the valve at the top of the forks. that sjust my .02 cents, and a few diffrent ways ive done itin the past.
    If they are bent at all then they are that much harder to get to slide out.
