Results 1 to 12 of 12
Thread: carb cleaning
    Jan 2005
    Slatington PA
    4,372
    carb cleaning
    On these old trikes the carbs can be outragously cruded up on the inside. The ones that set for years and years I'm referring to.
    I soak mine in a gallon of super duper carb cleaner over night but when finished I noticed it didn't take the chalkie lime deposits away. They were also in the throat tubes were the main and pilot jets go.
    What I did is went out and got some CRL which is a calcium, lime & rust remover. Soak it for 2 hours in the full strength solution and PRESTO....all gone!
    Just thought I'd let ya all know.
    Mike_Ham_250R's Avatar
    Mike_Ham_250R is offline Even team-red-rider is cooler then me. Arm chair racerJust too addicted
    Pennsylvania
    1,058
    yeah on my SX (from same guy as the YTM225) i just soaked it in a little carb cleaner and it went good
    -Mike
    Jan 2005
    Spruce Head Island, Maine
    893
    hmm, guess i shoul clean my carb someday here,, i have no clue what it looks like inside, but i want to rebuild it anyway.. are 4 stroke carbs much different from 2 stroke carbs??
    1983 Honda ATC 200x-shes a beater
    Past Rides:
    1982 ATC Big Red 200e (miss it more than i thought i would)
    1985 200x rode it for about a mile
    Jan 2005
    Slatington PA
    4,372
    Well certain 4 strokes are a lot more complex. These are quite simple though. Study a diagram 1st before you go tearing into it. There are a couple o-rings that can easily be lost if your not aware where they are.
    Excellant post, I never thought of using CLR on the older really bad carbs. Thanks for the tip!
    leprogle's Avatar
    leprogle is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2003
    New Brunswick
    345
    i've got an old really bad 200x carb, and i've been soaking it in varsol, but it's not coming clean. thanks for the tip, i'm going to try CLR
    Caution
    Do not "POP WHEELIES" and run for any distance with the ATC. The oil capacity is relatively small and the oil will drain out of the oil pump area thus causing loss of oil pressure, resulting in costly engine damage -CLYMER
    wheelie king's Avatar
    wheelie king is offline Aficionado of white surprise sauces. Arm chair racerRoostin Away
    Central FL USA
    1,174
    Also a commercial grade marine carburetor cleaner, like Mercury Power Tune, is excellent. Not the $1.00 cheap stuff from the auto parts store, you have to go to a marine/outboard shop. It is a foaming carb cleaner that really works wonders, and is not NEARLY as corrosive as CLR.
    1986 Honda ATC 200 S
    Some quads and a S x S
    Supporter of Uncle Rico's football camp. Since 1982.
    If you are reading this in English, thank a U.S. Military VET. ΜΟΛΩΝ ΛΑΒΕ
    Ontario, CANADA
    4,538
    Mercury power tune eh? well I think I am going to try that. I was going to use CLR but if its corrosive, I dont know if I will.
    RPFLU member and co-owner.
    Hardtails is all we do.
    #NOLINK
    #MAKEHARDTAILSGREATAGAIN
    #SUSPENDTHIS
    Aug 2004
    Ab Canada
    4,368
    Quote Originally Posted by Dirtcrasher
    me niether.....thanks man!
    1985 Tri-Z-
    Jan 2005
    Slatington PA
    4,372
    Quote Originally Posted by wheelie king
    what I use is in a gallon can about $12-15 or so.
    Corrosive?? CLR? Seemed to do a real nice job to me with out any side effects. I wouldn't use it 1st though. Use the strong stuff like you or I recommend and THEN if the lime doesn't go away try the CLR.
    I will keep the Merc Power tune in mind though.
    Thanks for the tip.
    Moncton Newbrunswick,Canada
    509
    anyone try CLR yet???just curious if it rrally does work well with out any bad effects..
    TRI Z Racer's Avatar
    TRI Z Racer is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2002
    Boscawen, NH
    342
    Merc powertune is made for 2 stoke outboards, you use it by spraying it into the intake under full throttle and for like 30 secs, then idle, then shut it off, and then full throttle agian. Or wahtever, there is some process outlined on it. It works great for its intended purpose, although i suspect there are much better things to use for cleaning carbs then that. My suggestion for cleaning a carb real good is to buy yourself a gallon of mckay carb dip, or NAPA stuff, its not too expensive and you can do dozens of carbs before you should replace it. In the long run its cheaper then buying a can or two of carb and choke cleaner every time you clean a carb. Heres what you do, drop your parts in, wait an hour or two, take them out, wash them off, blow out all passages with an air gun and spray off any remaining dirt, if any. voila. From working at a marina for the last 3 years ive seen some nasty salt water corroded carbs. i ahve found nothing better then this system. take it for what its worth
    1985 Yamaha Tri Z 260PV
    Suzuki Trail Buddy 50
