Results 1 to 3 of 3
Thread: Help 87 200x
    Feb 2005
    georgia
    20
    Help 87 200x
    My 87 200x Keeps Fauling Plugs What Is Stock Setting For Carb. When I Got It Had A Cobra Pipe Took It Off And Put Stock Pipe Back On.do I Need To Reset Carb. Thanks!!!!
    RichinMO's Avatar
    RichinMO is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2002
    Waynesville, MO
    321
    I dont know what the stock jets are supposed to be. When the Cobra was put on, they should have went up on the jetting; so when you put the stock pipe back on, that made it run rich and foul plugs. When you hit 3/4 to full throttle does it stumble and cut out?
    1985 ATC250ES
    1985 ATC250SX
    1984 ATC200S "Little Red" - Trailer hitch, Hondaline: Front and Rear Racks, Cooler Rack, Tripmeter, HL Grille, Rubber Footpeg Covers, Mudflaps.
    1985 ATC70
    2008 CRF230L - Dual Sport
    2016 TRX500 Foreman Rubicon Deluxe
    Aug 2002
    Creswell, OR
    889
    It does not matter right now what stock size is. What matter is what is in your carb now. You need to pull the carb and see what sizes are in it now. Someone may have changed it somewhere along the lines.
    www.3wheeler.org
    * * * Nothing scares me more than someone who knows, with certainty, what is best for me * * *
