Whats your preference, alum. or steel? What are the pros and cons of each?
I like steel,,,,, Aluminium is lighter, but steel lasts longer,,,, I do have a sidewinder aluminum sprocket on my XR500,,, and it has lasted years, probably 3 or 4 chains,,,,, Great sprocket but expensive
2003 honda shadow 1100 spirit
94 XR600R
70 qa 50 with a 90cc motor in it
87 XR80R
82 XR500R
1972 Honda z50A mini trail,,, Finally got a stock mini
1981 CR450R
2004 chevy silverado ls ext. cab 4x4 5.3L
this is my theory on chain and sprockets....
go aluminum but use o-ring chain and lube alot
go steel and use non o-ring chain and lube alot.
it may sound funny, but do it and u will see................ a mx pro rider taught me this...................![]()
I usually use steel with an o-ring chain, no problems,,,,, Keep in mind that ATV chains, take way more stress than dirtbike chains,,,
94 XR600R
87 XR80R
82 XR500R
1981 CR450R
Other than being lighter, there is no advatage to an aluminum sprocket. A steel one will last a lot longer. I got an aluminum rear for my R because the price and size was right, but its already showing showing wear when my steel one was still great after 3 times the time on it. Also if you dont have a swingarm skid plate, the aluminum takes a lot less abuse.
Ever notice nobody makes an aluminum front sprocket? Thnink about why that might be.
