Results 1 to 7 of 7
Thread: 250 big red
    May 2005
    upstate new york
    4
    250 big red
    hi guys im kinnda new to to this but i just got a 87 250 big red i friend trying to tell me that it should have a cluch but the gut i bought it from told me it s a semi auto would you guys fill me in on this love the trike
    Feb 2005
    Oregon
    772
    Auto-clutch
    1986 310R
    1975 F150 4x4
    1975 F250 4x4
    1968 F100 2wd
    2001 Dodge 1500 4x4
    May 2005
    upstate new york
    4
    ok this is the thing guys it only has a front brake handal is it supossed to have a cluch handal like i said dont know much about them
    Feb 2005
    Oregon
    772
    It should have a front and rear brake handle I belive. There is no clutch lever. you just let off the gas when you shift.
    1986 310R
    1975 F150 4x4
    1975 F250 4x4
    1968 F100 2wd
    2001 Dodge 1500 4x4
    broook's Avatar
    broook is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2003
    Newfoundland
    207
    Quote Originally Posted by aka_hunter2002
    How do you put it in reverse???? The left lever does two things. Along with the foot brake it works the rear brake, [two cables]. and also along with the red button shifts it into reverse.
    May 2005
    Pahrump, NV
    8
    The HONDA ATC250es (Big Red) is a semi-automatic transmission, in that you don't have to pull in clutch handle (because it doesn't exist!) to shift. The left brake handle (rear brake) should also have a button on it (a red one with a white "R" on it). This is your reverse button. From the sound of things, you're missing this lever.
    In order to shift into reverse on a big red, you have to shift down to N, press the red button, pull the brake lever back (while holding down the button) then kick the shift lever DOWN...now you're backwards. Up twice on the shift lever and you're back in 1st.
    That lever should be relatively easy to come by, since it's the same mechanism that's used on the 4 wheeled version of HONDA ATV's today. You're gonna want to make sure you still have all the cable.
    Bob
    2 1987 HONDA ATC250es Big Reds
    May 2005
    upstate new york
    4
    ok guys thanks alot i do have the reverse handal on it and it works good only thing im missing is the front brake handal and cable but thanks on the input guy i love the site
