changeing oil filter on big red.
I want to confirm I changed my oil filter correctly the instructions are a little vague.
when I pulled the cover off, a spring popped out. were does this go? I put the filter rubber side onto the tube piece of the cover, and placed the spring on the engine side of the motor, using a small amount of grease to hold it against the wall were it seemed to go.
did I do this correctly?
1983 honda 70atc, als,ot done, need throttle cable and assembly. PM me if you have this.
1985 honda es 250 big red.
85 percent restore. 10x10 douglas 190's 22-11-10 at 489's. 12x7 itp c series 24-8-12 swamp fox. some accent painting. snorkel everything and a custom PCV system. moose air filter. cobra utility exhaust. 2.5 um wheel spacers.
A trike to show up the modern utilitys
2002 scrambler 400 2x4 uni pod filter, lots of weight shaving, v force reeds, HPD race pipe, 39mm pwk or 34mm, 12-1 head, trail porting, custom clutching, hole shots on t-9s +1 all around. works shocks . trail bike with drag tweeks.
