Results 1 to 8 of 8
Thread: Piston Installation and Speedo Wiring
    Jan 2005
    RI
    2,530
    My speedo head came in, and where do I hook the wires for the light up to? I assume in the headlight casing, but the wires and connectors match the tail light connecters perfectly? Should i just make sure brown is connected to all browns and green is spliced together with all greens? (my green wires have no connecters, just spliced with tape...)
    How do you compress piston rings without a ring compressor and without wanting to kill someone? Any one have any tricks?
    Where can I find a correct sized compressor for my little 200s piston?
    Thanks,
    Mike
    Jun 2003
    South of Rochester, NY
    3,470
    What machine is the speedo going on? I know my NOS Hondaline 82R, 350X, and 110/185/200/200E kits "splice/jumper" into the headlight wiring. My HA2 250R NOS kit though has a sub wiring harness that runs the feed all the way back to the taillight to power the speedo light.
    Bruce
    '86 ATC350X - 'Go-Go Girl'
    '85 ATC70 - All Original
    '83 Suzuki ALT125 - Pieces
    Jan 2005
    RI
    2,530
    its goign on a 85 200s...i assume i just gotta splice it in...theres a male and female connection for each green and brown colored wire.
    Jun 2003
    3,470
    Ok... unplug the green from your headlight. Then use the male and female connections to hook into the green connections on the speedo. Do the same thing for the brown connections.
    Bruce
    Jan 2005
    RI
    2,530
    thanks, youre a great help.
    Jun 2003
    3,470
    Quote Originally Posted by DeePa
    No problem man... that's what's the board is all about!
    Hondaline Hartman....
    Jan 2005
    RI
    2,530
    and how about them piston rings
    Aug 2004
    Ab Canada
    4,368
    for the rings, get the on the piston, install the piston on the con rod, then slide the cylinder down to the top of the piston, sqeeze 1 ring at a time and slide the cylinder overtop as you go, make shure your top ring end gap is 180 degres off from the second ring and that the oil ring is in the middle of them
    1985 Tri-Z-
