well i think the bearings are shot or something.. it shakes if you push it sideways and it aint the axle nuts...and if you look on the sprocket side and do it..you can see the axle just kinda wobble..not very much but enouugh to notice..is that the bearings?? how much do they cost and is it hard or time consuming to fix?
ed. they are not hard to change out. but if you are going to change the axle bearings you might as well change the swing arm bearings as well. if you look on ebay you can find a set of bearings and seals for about $20, which isnt bad. dadsteck sells a full swingarm pivot bearing package minus the bolt, item number on ebay is(one of many he has)4549055124. if the swing arm bolt does not come out easy you may have to smack it with a sledge
