Results 1 to 11 of 11
Thread: Bought a 85 250 big red in bad shape
    svo58 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2004
    clifton park,saratoga county,N.Y.
    166
    I just bought it.It don't roll,maybe the bearings or the brakes are shot.It's just about all their,it's missing the brake handles(both sides),that's what i can see from the picture.I'm sure there is other little stuff missing too.My question is i am going to start with the bearings,the front is easy but the rear is shaft drive ,how hard is to change them.The rear swing arm ,how do you check it and if it is bad ,is it fixable(i am going to get a manual ,i want to start rite away on the frame and cable ect.)The 250 still has the origanal tires on ,1 is flat the other 2 hold air.Is this the place to start ,(the out side of the big red.) and do the motor last.I hope it worth putting this 250 back together,if not it will keep me out of trouble anyway.thanks for any help or try to stear me in the rite direction anyway.............svo58
    84 big red 200es with speedo
    84 70cc ATC- new top end ,rear rack, head light and tail light
    85 250es big red
    85 250sx
    Pa.'s Highest City
    8,058
    I would focus on getting it rolling before worring about anything else. It is possible to change the rear swinger bearings. I've done it on a 250sx already. It's not that hard but a manual will help tremendously.
    Opelousas, Louisiana
    1,337
    i think he means "BIG RED"
    1986 350X K&N filter, DG Krome Power exhaust
    1982 110 UNI filter, Cobra megaphone exhaust
    1982 honda 110 exhaust for sale, PM me.
    Jan 2005
    Slatington PA
    4,372
    1st thing is to set it up on jack stands or whatever and see if the brake caliper piston is froze in the out postion, pushing the pads against the rotor. Actually you don't need it on stands for that.
    Could be as simple as the brake cable being frozed up also. Make sure the caliper arm that cable attaches to is all the way in the piston release postion.
    Take the chain off and see if you can turn wheels freely. Check the axle trueness by eyeing the axle ends and see if they rotate perfect .
    See if there is play in bearings by trying to move the whole axle assembly side to side with wheels on. With wheels off try turning it and see if it "feels" dry as your turning hit. You can sort of hear them too if they are shot.
    Pa.'s Highest City
    8,058
    my bad. I thought big reds WERE shaft drive.
    Jan 2004
    216
    Beat me to it, I was just about to say that.
    96 Warrior - 90 Moto4 - 86 Big Red - 85 Yamahauler - 84 Yamahauler - 82 Big Red - 79 Trail 90
    Jan 2004
    216
    Huffa just said take the chain off, and try to turn the wheels, you can't take the chain off because it's a shaft instead.
    Pa.'s Highest City
    8,058
    I'm all messed up now. lol I must be reading something wrong. I said that the 250sx rear end was similar to that of the bigred. Where'd my other thread go? Anyway Ya, I would have to agree with Huffa on that one though. You should focus on getting it rolling then running.
    Mar 2003
    Barnesville,Ohio
    2,298
    changing the bearings in a 250 big red and a 250sx would have very similar procedures
    1985 Honda 350X - a lot of performance stuff, everything but a cam, hope to get one soon
    1984 Honda 200ES
    198? Yamaha YT60 Tri-Zinger
    TrikeFest '04 & '07 Survivor
    Mar 2005
    Underwood North Dakota Tiger country
    1,055
    svo if you need parts i have a machine that was so ruff. it could not be saved but lots of good parts to save others
    Mar 2003
    Australia
    1,919
    For god sake. If you know nothing about the bike why bother replying! The 250es is a shaft drive and it also has drum brakes. So there is NO chain and NO Caliper/Rotor!
    The bearings arent all that hard to change in the rear end (not that I have done the swingarm). I have done the diff ones and they werent to bad. Like someone else said the manual will be invaluable.
    Matt
    1980 ATC 70 Needs Restoration
    1985 ATC 250es Fully Refurbed
    1986 ATC 350x Mint Original
