Results 1 to 15 of 16
Thread: 15 tooth front sprocket on a 250R?
    Nov 2004
    Waterloo IL
    2,701
    Will it fit? I'm thinking it might be too big. What happens if the chain falls off? Am I asking for trouble by wanting to do this? I hear going up one tooth in the front is the same as dropping 3 in the rear. If this is the case I will have to drop 6 in the back and shorten the chain. I think with the 15 on front I can use the same chain and always switch back if I don't like it.
    http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
    EDIT: The ebay link is an example of what I am talking about, it has nothing to do with the fact that it is an ebay auction so I think it belongs here.
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    03 400EX- XR650R engine
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86,86,86,86,86 Scrambler
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    84,84,84,84,83,82,80,79 ATC70
    82,79 XL500R
    83 ALT50
    79,78,77,77,76 XT/TT500
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72,71,70,70,70,70,70 CT70H
    72 SL100
    70,69 Z50
    May 2005
    NC
    38
    dropping 3 in rear is similar to 1 in front. with your adjustment you can most likely put the 15 on w/o shortening the chain.
    Jan 2005
    Slatington PA
    4,372
    A 15 toother is actually better for the chain anyway.
    It makes the chain go around in a slightly less arc and helps keep it farther away from the swingarm buffer on most moderls.
    I'd never go smaller on the front for those reasons. I'd rather go more on the back.
    Just a case of knowing how large the sprocket is towards the stock one in reguard to case clearence. You could always call supplier and ask to measure, that's what I would do anyway instead of having to send it back.
    TRI Z Racer's Avatar
    TRI Z Racer is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2002
    Boscawen, NH
    342
    dont forget, you probably know this but just in case, if you just put a bigger front sprocket on and leave the rear the same, you loose your low end and will be using the clutch alot more for starting and going real slow.
    1985 Yamaha Tri Z 260PV
    Suzuki Trail Buddy 50
    r00sty's Avatar
    r00sty is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2002
    Hemlock 14466
    415
    It also takes quite a bit more of your power to turn the larger front sprocket.
    I noticed a little at the top end on my 250r when I went up a tooth, but it seemed to take longer to get there.
    I just got a 14 for the x and am going to install it today and see if I like it.
    CHEAP, CHEAP, CHEAP at Rocky Mountain ATV like less than $10, fyi.
    Old enough to know better, but still young enough to not care!!!
    Reality is for people who can't handle drugs!!!
    86 XR250RX Custom but all Honda...
    92 Yamaha Vmax
    81 Yamaha XS1100
    04 Polaris 700 Twin EFI
    86 TRX 250r
    Nov 2004
    Waterloo IL
    2,701
    Quote Originally Posted by TRI Z Racer
    Yeah, I'm kinda of in the opposite direction right now. I have 18's on back and it's too low for my liking. The 4-wheeler I have is geared really high and I'm used to that and I like it. I never use first gear on my 250R while riding.
    It has also been suggested that my bike will be quicker if I gear it up. I know that doesn't make sense but I've seen that happen so that's why I want to try this. Example my 450R has better accelleration with the stock 14 tooth rather than a CRF sprocket which is a 13. Lost of people have found this out. I just talked to my cousin and he has a 15 tooth and a 16 tooth for a 400EX. I'm not sure they are the same but I'm gonna try the 15 out when I get off work.
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    82,79 XL500R
    83 ALT50
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72 SL100
    70,69 Z50
    Michigan
    1,220
    A 15 fits easy but you have no case protection. I'm running 15 front 37 rear on the trx and am getting a 16 front then I will have every available sprocket for front and rear.
    Dec 2002
    Boscawen, NH
    342
    i didnt think about the rear tire sizes, with 18's your def gonna have to go up on the front spocket, or down on the back, fronts are cheaper and achieve more of a change 1tooth = 3 teeth. sounds like you got it under control
    Nov 2004
    Waterloo IL
    2,701
    Quote Originally Posted by x.system
    Can I keep my stock case saver and sprocket cover? I don't want to have to leave the sprocket cover off.
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    82,79 XL500R
    83 ALT50
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72 SL100
    70,69 Z50
    May 2005
    NC
    38
    i wouldent be concerned about the sproket cover, more so the case saver
    Lots_Of_Nothing's Avatar
    Upstate NY
    2,665
    Quote Originally Posted by r00sty
    I like the 14 toother on my 350. It still has enough power to climb the rough stuff, and lift the frontend up, but it has that extra speed on straightaways. I'm geared 14/40 with 22"s.
    About the R 15 tooth, you cant run the case saver with it.
    Nov 2004
    Waterloo IL
    2,701
    Case saver won't work huh? I don't really like that. Just wondering what the stock gearing on a 350X is? You have 22's and I have 18's that a big difference in gearing right there.
    Anyone know if I can run the case saver and sprocket cover with a 14 tooth? If so I'm gonna get one of those and just drop teeth in the rear if I need more. I still have the stock rims and tires maybe I should put those back on too? I really like the 18's though.
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    82,79 XL500R
    83 ALT50
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72 SL100
    70,69 Z50
    Upstate NY
    2,665
    Quote Originally Posted by Blown 331
    stock gearing on a 350x is 13/40 with 22" balloon type tires.
    Not sure if the 14 tooth will work with the case saver on a R, I know it does on the 350.
    Michigan
    1,220
    Yes, 14 and a aftermarket case saver will work but 14 is as big as you can go and still use one. There is only about a 1/4" between the case and chain with a 15 tooth. I had to do it for top speed on ice but racing TT I droped back down to a 14 with a case saver.
    Jun 2003
    South of Rochester, NY
    3,470
    My 82R had a 15 tooth on it when I got it. Holic gave me a front sprocket cover and it wouldn't fit. I went back to the stock 13 tooth and mut the cover/saver on it. I can definitely feel the difference!
    Bruce
    '86 ATC350X - 'Go-Go Girl'
    '85 ATC70 - All Original
    '83 Suzuki ALT125 - Pieces
