Thread: 350x headlight on 250r??What am I Missing?
    faf_racing's Avatar
    faf_racing is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jan 2005
    pensacola florida
    187
    I installed the 350x headlight assembly on my "R" and when started it the bulbs worked for a second and went out, I assume they blew cause (they don't work now) Does the voltage regulator from the "R" too many volts for 350x headlight assem.?? And if so do i need too install a 350x volt reg? If "YES" will the plugs from harness be the same?
    Anaheim
    1,270
    change the wattage of the bulbs to higher watts and they will be better i think they are 45 watts a peice and 55 should do * good, dont take my word for it on the watts but i know higher watt bulbs is all * need.
    adam
    86 ATC 500R the duner..
    85 ATC 500R...the not quite finished faster duner
    1985 ATC 250R Bone stock!!
    1985 ATC250R mx/duner
    1986 TRX370R MX/Duner
    94 Banshee 400PV Cheetah 105RWHP
    Jun 2003
    South of Rochester, NY
    3,471
    Quote Originally Posted by RideRed250R
    adam
    The 350X bulbs are a 35/36 Watt Halagon bulb for each bulb. Seems like ScottZJ had a similar problem. I wonder... but not a suggestion.... I wonder if you ran the bulbs in series, if that would work. The obvious downfall would be if you blow one bulb, they both go out in series. However, I've seen a lot of 200X's with 350X lights, and some 250R's with 350X headlights, so I don't think it's an issue with the way you hooked it up, else we'd have a zillion threads about this. I'd be snooping around the voltage regulator.
    Bruce
    '86 ATC350X - 'Go-Go Girl'
    '85 ATC70 - All Original
    '83 Suzuki ALT125 - Pieces
    ATCnut is offline Got The Holeshot Arm chair racerJust too addicted
    Nov 2002
    Auburn Washington
    799
    You want to run lower wattage bulbs, not higher. I think the stock bulb is a 45W, so you add the wattage of the two 350X assembly bulbs together to get the equivelance. They make 25W bulbs that fit, a pair of those is about right. Not all Honda trikes had a regulator, I am not sure about the air Rs. If it does not, then putting a 350X or liquid 250R regulator on will work. If it has one now, the symptom you discribe is what happens when the regulator is bad.
    ATCnut
    82 185s - sold
    83 200x (hopped up)
    84 200x (stock)
    84 70 (lost this one to the DMV)
    85 70 (soon to have lights, a foot brake, and CDI ignition)
    84 200es (parts trike) - sold
    85 350X (the best)
    85 350X (siezed motor, dream of a poweroll kit someday)
    85 250sx (frame was trash, got parted out)
    86 250sx (the tractor)
    86 250sx (a nicer tractor)
    86 250sx (an even nicer tractor)
    87 200x (parts trike, its really rough, a dog was chewing on it for a while)
    87 250es Big Red (the tank!!)
