this was my first post about the problem
http://www.3wheelerworldforums.com/s...ghlight=clutch
since then i had a guy take it apart and look at it, he said he just put it together again, reajusted it and it worked good. But then it slowly started to drag a little and then it got worse and now it isnt disengaging at all.
I think I have an idea of what it might be, I was thinking it could be the ajuster inside the engine backing off a bit. i might try to put some locktite on it or something.
what other things should i check for when i'm in there?
If the plates were worn out, would the clutch be slipping and not grabbing?
thanks
