1. will a trx r rear rotor fit on the 86r atc rear?
2. what rear rotors will interchange with a 350x? ( 250x?)
id appreciate the help .
max
max
3-85 ATC 70
86 ATC 250R
86 WETBIKE
01 KX250
2011 KAW SXR800- 35YR EDITION
05 HERITAGE/SPRINGER/SOFTTAIL
a 86/87 200x rear rotor will fit, also if you have 250r parts you can put a 250r caliper, plate, disc and hub on, but you will need to machine off 5mm or something like that off the inside part of the brake hub MR. ATC on 3w.org had a sticky about this.
a 200x rotor will fit a 350x?
3-85 ATC 70
86 ATC 250R
86 WETBIKE
01 KX250
I know a 86/87 200x one will, they have the same honda part number.
A 83-85 200X REAR rotor works on the FRONT of a 350X/250R. Pretty sure the 350X rear rotor will work on the water cooled R's.... it's a 4 bolt pattern rotor.Originally Posted by max
'86 ATC350X - 'Go-Go Girl'
'85 ATC70 - All Original
'83 Suzuki ALT125 - Pieces
__________________
so then an water cooled r's rear rotor would fit on a 350x?
3-85 ATC 70
86 ATC 250R
86 WETBIKE
01 KX250
Yep.... I bought some NOS ones and pretty sure they were listed as 85-86 250R/350X rear rotors....
I bought a TRX wave rotor for the rear of my 86 R.
http://photos.yahoo.com/dynofox250 (TF 03 pic's)
Trikes: Restored '86 ATC 250r, original and mint '83 185s
Quad: '86 TRX 250r
Sled: Rev X 800ho mod
Bike: '00 ZRX 1100
TF '03 and '05 Survivor
