Results 1 to 8 of 8
Thread: Yamaha 225 YTM DXK DXL and DRS ????
    May 2005
    Illinois
    65
    Found a new stock piston rings and pin for sale for a 225 Dx . My question is it lists that the piston and parts are for a 84-86 dxk/dxl or an 86 drs. I have a 1985 DX and aminterested in the parts but have no clue what my trike is be it a dxl dxk or drs. How can I tell and what do all these stand for?
    Hornetpowerspor's Avatar
    Hornetpowerspor is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2005
    Michigan
    294
    I had a 225 DR. It was black with reverse. I believe the "R" in DR stands for reverse. As for the others I dont know.
    Jun 2003
    South of Rochester, NY
    3,471
    85 should be a 225DXN or a 225DRN, depending upon if it has reverse or not. In either case, the motors were basically the same, so you are safe buying that piston and rings.
    Hey... welcome to the board!
    Bruce
    PS... the last letter is the year....
    K = 83
    L = 84
    N = 85
    S = 86
    '86 ATC350X - 'Go-Go Girl'
    '85 ATC70 - All Original
    '83 Suzuki ALT125 - Pieces
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    Post some pics of that Tri Moto?
    May 2005
    Illinois
    65
    I don't have any pics of my 225 dx . I just bought it about 2 weeks ago and need to do some work. It is yellow with no reverse though. I just got my new rear replacement bearings in the mail today and will see if I can succeed with that project. I have been looking at the schematics of the rear end and am trying to decide how hard the bearings will be to change. No problem if the axle will slide all the way out of the existing bearings without pulling the shaft drive gearbox. Good luck to me.
    Jan 2005
    Slatington PA
    4,372
    The axle slides right out. Just have to tap on it for the 1st 2" or so. Here is what it looks like on the inside.
    You remove it (veiwing from behind) L to R. The rotor side bearing stays on axle as you remove it.
    May 2005
    Illinois
    65
    Got my bearings in tonight. Only mess I made was that I beat it out of the rear end by tapping on the left rear with a 1inch chunk of brass bar. Well as you can guess I messed up the threads where the cotter pin fits in the hollow part of shaft. I had to cut the end off to good threads usea thinner flat washer and redrill for a cotter pin. Otherwise it was an ok job. Thanks for the help.
    TRI Z Racer's Avatar
    TRI Z Racer is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2002
    Boscawen, NH
    342
    at least you used brass to beat it.... if you used stell you would have been in alot more trouble
    1985 Yamaha Tri Z 260PV
    Suzuki Trail Buddy 50
