Results 1 to 8 of 8
Thread: Best Paint
    Mar 2004
    Fond du lac,WI
    658
    Best Paint
    Whats the the best paint to use on the frame??
    Jun 2004
    geraldton, west australia
    1,068
    depends on your budget.
    you can either go or powder coat.
    LIVELOVERIDEDIE
    1981 Honda Atc 124R-Racer project
    2005 Giant STP 1- rollin' on 26's
    Trackburger's Avatar
    Trackburger is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2005
    Virginia Beach
    254
    In my opinion, powder coat is the best, its not even as expensive as some may think, the only thing that make it seem expensive is that it needs to be sandblasted before its powdercoated and that is where most of the cost comes from. If you want to go with the method, PJ1 makes most factory colors and seems to be pretty durable. Thats what I used on mine. I sandblasted it myself,primed it real good, used the PJ1 "Honda Red" and slapped on a few coats of clear. Looks factory fresh!!!
    1985 Honda ATC 250ES BIG RED
    1985 Honda ATC 350X
    1985 Honda FL670R Odyssey ROTAX conversion
    1993 Honda Type II 200
    2003 Honda TRX 90
    2006 Honda TRX 90
    Jun 2004
    1,068
    yes, good prep and primer work is the key to sucess while using s.
    LIVELOVERIDEDIE
    Mar 2004
    Fond du lac,WI
    658
    Yea i mean spray paint. so the i should sand it and also prime it
    MN250R's Avatar
    MN250R is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2003
    Minnesota
    285
    Por15
    They have really strong paint, check out there site at
    www.por15.com
    1986 ATC 350X
    1986 ATC Big Red 250ES
    May 2005
    Nome Alaska
    147
    I used Extend Rust-Destroyer. It's a good paint/primer, and it doesnt require sandblasting. Just a quick Dremel job with a wire wheel will get the frame ready for paint...
    Quads are for GIRLS!
    Trikes are for REAL MEN!
    83200e's Avatar
    83200e is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2004
    Arkansas
    356
    Quote Originally Posted by KayodicWeazel
    LOL,I couldn't imagine having to strip my frame with a dremel.
