Thread: DG pipe on 110
    Apr 2005
    Blue Ridge Mtns NC
    59
    Question DG pipe on 110
    I just installed a DG pipe on my 83 110. I am having trouble getting the carb adjusted. It starts easy, idles perfectly, but when I really lay into the throttle it wants to hesitate and die. If I gradulally give it gas it runs great.
    What needs to be done to correct the hesitation? I have played with the needle position. It seems to help the hesitation when I raise the needle, but then it idles like crap. I have since moved it back to the middle position. Can someone help??????????
    Washingtons Crossing, Pa.
    2,977
    Sounds to me that your main-jet is too lean. Usually (but not always) when changing to an aftermarket pipe, you need to bump up at least one size on the carbs main-jet to compensate for better flow. I'm not sure what the stock size is on a 110 in your area of the country (I'm assuming you're more than 2500ft above sea-level from your signature), so see your local Honda dealer for the jet.
    Jul 2004
    Mud hill. close to water !
    3,658
    i'd move the clip back to where it ran better on hard throttle..
    then re-adjust the idle and air/fuel for better idle.
    Currently :
    May 2005
    Nome Alaska
    147
    Hey dude, is that DG pipe any good? I've been having trouble choosing between a DG pipe and a Cobra...
    Quads are for GIRLS!
    Trikes are for REAL MEN!
    Apr 2003
    HARTFORD CT, USA
    478
    go up on the main.
    'WHEN IN DOUBT.........GAS IT!'
    87 KXT250B2 Tecate
    86 ATC250ES BIG RED
    85 ATC350X
    85 ATC70
    'A FEW IN PARTS'
