Thread: How does your tool box mount in your truck?
    Jan 2004
    216
    I know someone out there has to have a toolbox in the back of their truck. My uncle gave me his old one when he sold his truck and I'm just curious on how it mounts in your truck. I want to be able to put all my riding gear and tools and what not in it, but not until I anchor it into my truck somehow. Any REASONABLE suggestions?
    96 Warrior - 90 Moto4 - 86 Big Red - 85 Yamahauler - 84 Yamahauler - 82 Big Red - 79 Trail 90
    rustbucket is offline At The Back Of The Pack Arm chair racerFirst time rider
    pentwater michigan
    180
    my truck has a bolt going through the bottom outer edge (open the lid and you'll see a hole) holding it to the box
    1980 trimoto 125 mods include a ripped seat broke fender and bent handle bars
    1981 trimoto 125
    1971 suzuki ts 185 it will spank a 200x
    1966 gmc 3/4 ton
    250rAL is offline Just Too Addicted Arm chair racerJust too addicted
    Sabula,IA
    620
    I use a bolt through the toolbox and the siderail of the truck (one on each side) but I don't put a nut on it. Instead I have hitchpin clips. That way I can quickly take the toolbox off if I need the extra room. I put the bolts up through from underneath with the clips inside so they can't be removed if the box is locked.
    __________________
    '85 ATC250R
    .030 Over Wiseco
    FMF Pipe/Answer silencer
    36PJ Keihin
    K&N
    Boyesen reeds
    Magura hydraulic clutch
    Roost Boost
    MSR bars
    OMF swingarm skid
    ITP Beadlocks
    Three Wheelin' Since '84
    wanta86r's Avatar
    wanta86r is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2004
    mn
    385
    I use j-hooks- drill one hole on each side of the inside of the toolbox. Push the j-hook up from the bottom. The"J" part of the hook holds on to the lip of the box rail and you then put a nut on the inside of your toolbox where you drilled the hole. This method eliminates the need for drilling holes in your truck box
    Mar 2004
    Fond du lac,WI
    658
    i use steel screws and screwit right to the side
    I've done them 2 different ways. One way I used a 3/8 threaded stainless rod and bolted that with thin hex nuts into the truck metal siderail - then just a wing nut held the toolbox down. The other I attached it to the plastic bedliner with stainless steel wood screws.
