82 250R exhaust questions....
Ok... my 250R is 80 over and when I bought it, it had an "unknown" aftermarket exhaust on it. It also had an airbox that had holes cut in it.
Before I did too much riding, I bought a Keyster carb rebuild kit, another air box, and a stock expansion chamber. I cleaned the carb and installed hte carb rebuild kit, and also bought some different size jets to have on hand. At the same time, I went back to the stock enclosed airbox (Uni AF), and stock expansion chamber. Did a plug test and I was right on the money!
My question now is, the trike had been puffing some smoke out where the expansion chamber ataches to the head. I fixed it was a stock NOS gasket and a flange ring. Now, it's sealed nice around the exhaust, but seems to be "smoking" more than it was.... still runs great, just noticing more smoke in the exhaust gas.
Since it might have been pulling some extra air in the exhaust, do you think I'm just running a little rich? I have a DG expansion chamber hanging on my wall and just got a DG silencer in the mail today, you think I ought to put that on and do some chop tests? Either way, I'm putting the DG silencer on... it has some aftermarket silencer still on it... I bought a stock one awhile back, but the internals are bout gone in it, so I never changed the silencer when I put the stock pipe back on it.
If I put the DG expansion chamber and silencer on, how much would you estimate I'd need to change my main jet by?
Bruce
'86 ATC350X - 'Go-Go Girl'
'85 ATC70 - All Original
'83 Suzuki ALT125 - Pieces
