Results 1 to 11 of 11
Thread: jumping the hard tail
    Jan 2005
    Spruce Head Island, Maine
    893
    anything bad about jumping with a hard tail?? i took mine over a few today, and everything seems fine, landed correctly, little rough though ... i was only worried that it might be hard on the axle to do that often.
    1983 Honda ATC 200x-shes a beater
    Past Rides:
    1982 ATC Big Red 200e (miss it more than i thought i would)
    1985 200x rode it for about a mile
    Aug 2004
    Ab Canada
    4,368
    i used to jump mine......i bent the hell out of the axel last time around so im gona not do that so much......lol
    1985 Tri-Z-
    Brandon, Manitoba
    2,209
    probaly be harder on your back. haha. I jump mine of little jumps all the time, i dont see a problem with it.
    Aug 2004
    PA
    190
    I "bunny hop" my trimoto ALL THE TIME about a foot or two. Never had any problems, just don't get too crazy. I even widened mine 3", so that makes it even worse.
    Jan 2005
    893
    alright, i dont get too much air, just enough to feel it.
    Past Rides:
    Jul 2004
    Mud hill. close to water !
    3,658
    Get on the pegs and flow with it.. my big red 200 es was a like jumping a grand piano but as long as you don't weigh 300 + lbs and you stand and do the BMX thing.. ain't so bad.
    Currently :
    Mar 2003
    Barnesville,Ohio
    2,298
    you can jump them...but if you jump to high, you will bend the axle...mine on the big red is
    1985 Honda 350X - a lot of performance stuff, everything but a cam, hope to get one soon
    1984 Honda 200ES
    198? Yamaha YT60 Tri-Zinger
    TrikeFest '04 & '07 Survivor
    Washingtons Crossing, Pa.
    2,977
    Jumping is ill advised ...... although I used to do it on my '84 200S all the time. If you go too high or get off kilter on take off, you will pogo out of control.
    Yamahammer490's Avatar
    Yamahammer490 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2003
    254
    I used to run my YT 175 over little jumps all the time and it was fine. Just keep things relatively calm and you should be fine.
    CURRENT RIDES:
    1988 Tri-Z 350 Twin
    1985 1/2 Tri-Z
    1984 IT490
    IMPORTANT: Those of you with an overwhelming fear of
    the unknown will be gratified to learn that there is no hidden message revealed by reading this backwards, so just ignore that Alert Notice from Microsoft.
    Moncton Newbrunswick,Canada
    509
    well i used to jump my 185S over small jumps,i was worried about breaking the frame i saw a friend break the fram in 2 spots jumping a 200S and the jump was maybe 2feet tall....
    May 2005
    Nome Alaska
    147
    I jump my 110 all the time, not huge scary MX-type airs, of course, but a good 2-3 feet. The front end is welded up cause I broke it once, and its a good machine, just a bit bouncy on landing.
    Quads are for GIRLS!
    Trikes are for REAL MEN!
