Results 1 to 15 of 16
Thread: 125m axle nut welded on with rust :(
    Ive tryed for the past 2 days on and off trying to get the axle nut loose on my 84 125m ive sprayed it down numorous times with oil and no luck its like the dang thing is welded on.
    any tips on how * guys remove the crazy rusted axle nuts that look like that have been untouched since 1984?
    also if ** standing behind the 125m dose the nut lossen by turning it towards the front end or backwards towards the ground?
    1983 Honda 110
    1967 Mustang
    Houston,Texas
    1,044
    Its standard threads. Lefty loosy-righty tighty.
    "I am going out of this world.....the same way I came in...screaming and covered in blood."
    Sep 2003
    El Paso Tx
    1,123
    Impact driver. Or a hot wrench.
    So many idiots that can't ride a motorcycle, so few hours to put my boot in their seat!
    Myeh heh heh heh heh!!!
    man this sucker is on there,maybe ill try to weld toghter a wrench outta steel so i can get some leverage on it.
    1983 Honda 110
    1967 Mustang
    Jul 2004
    Mud hill. close to water !
    3,658
    Got a torch ? Put the heat to it.
    Currently :
    Jul 2004
    3,658
    Also.. take a stiff wire brush and clean the exposed threads as best you can as close as possible to the nut so that when it does more, it don't get stuck full of rusty grit..
    either a BIG adjustable, or in my case i used 2 pairs of ( not sure the name ) but they have notches that you can pull the handles apart and make them wider or narrower then once in a grove pull the handles together again.... i wish i knew the name of them.
    Currently :
    ya think a lil propane torch would heat it up enough i was gonna go buy one and try that.
    1983 Honda 110
    1967 Mustang
    Jul 2004
    3,658
    those tiny torches don't put out alot of heat.. but you don't really want to make it glow either unless you plan to replace your rear bearings...
    I find that once hot.. penetrating oil seems to get sucked in crevices better than when cold.... so heat it up best you can with what you got.. spray it with lube and give it a heave-ho !
    Nothing beats having the right tools for the job.. but we can't all afford a garage full of every tools made now can we ? !!!
    Currently :
    I have 2 roll away chests fulla tools but nothing seems to get off a 20+ rear old rusted axle nut haha
    i have a entire rear end i wanna put in the bike thats why im trying to get it off the brakes seized up and the bearings are going south.
    ill try the lil torch method and somemore oil while its hot thanks
    1983 Honda 110
    1967 Mustang
    Aug 2004
    Ab Canada
    4,368
    2 people 1 with a pipe wrench with a 4 foot snipe on it and the other holding the tire while the other jumps on the snipe....lol
    1985 Tri-Z-
    Im gonna have to break out my big gun my 6'4 260 pound brother in law hhahaha maybe he can get it loose.
    1983 Honda 110
    1967 Mustang
    Nov 2004
    lancaster, sc
    84
    get a socket on it, and put a long cheater bar on the ratchet. i'm pretty sure this will work. its all about the leverage.
    Jun 2004
    potsdam ny
    1,227
    heat up the axle in the center of the nut and when it gets red hot ram some candles on it until it wont melt the wax anymore, it will suck in the wax and use it as lube...try it, it works.
    Feb 2006
    Central Florida
    1,090
    hot wax...... how kinky
    quiet people seem intelligent
    Jan 2005
    Wasteland Michigan
    149
    Quote Originally Posted by hrc85250r
    PARIFIN WAX, it works. its a old engine rebuilder trick to get oil galley plugs out.
    i use KROIL for penitrating oil ( IT IS THE BEST ) http://www.kanolabs.com
    not cheap but the best!!!.
    use map gas ( yellow tank ) instead of propane. it will get a 3/8 bolt red.
    get it red hot then tap on the nut and shock it loose ( do this a few times )spray it with penitrating oil after it cools some, but not when its hot enough to evaporate and the heat will draw the oil in, water will work sometimes too.
    larry
    RIDE SIDEWAYS
    got another addiction
    Honda's
    86 ATC 350X
    T/F Survivor 06 / 07
    SANDPUPPI Survivor 07 / 08
