Results 1 to 15 of 27
Thread: 125m help please
    125m help please
    I finnaly got the axle nut loose on my 125m i removed the cover that covers the brake drum but the drum wont slide off the axle im trying to replace the entire rear hub and brake but i cant get the drum to budge i tryed heating it,oiling it rubber mallet nothing moves it.................anyone have a manual that they can scan me the page of how to take the rear end apart?
    im about 2 steps away from giving up on this trike and selling it
    1983 Honda 110
    1967 Mustang
    May 2005
    NC
    38
    a rubber mallet wont do any thing any way. you need big a rawhide . ive got one and it works great for stuff you dont want to mess up but want to slam it
    since i have another setup for the back a new drum and brake and the housing i hit it with a regular and it still dosent budge one bit :/
    1983 Honda 110
    1967 Mustang
    Jul 2004
    Mud hill. close to water !
    3,658
    back out the adjuster to the max to bring the shoes in as much as possible... you probably have a groove in the drum and the pads are resting in them.
    Currently :
    The pads are loose inside the brakes didnt work i can look threw the holes on the drum and see the pads flopping around a bit.
    should the drum slide right off? or is there something else i have to do to remove it?
    1983 Honda 110
    1967 Mustang
    Aug 2004
    Ab Canada
    4,368
    block of wood and sledge on one end of the axel-nuff said.
    1985 Tri-Z-
    Ive tryed to hit the axle with a block of wood and a on both sides of the axle lol it dont move if i remove the axle nuts the axle should slide out to the side with the chain on it right?
    is there something im missing here cause im losing my patience with it
    1983 Honda 110
    1967 Mustang
    May 2005
    NC
    38
    cutting torch
    Quote Originally Posted by cool_racer
    cutting torch
    Id break down and take it to a honda dealer before id go after it with a cutting torch.
    1983 Honda 110
    1967 Mustang
    May 2005
    NC
    38
    Quote Originally Posted by 42F67N
    lol, i feel ya. i know what id be doing thouh
    Apr 2003
    Central New York
    1,860
    If you have the Parts
    If you have the Parts to replace whatever gets torched I would start Choppin that ass up. Theres a Limit a man reaches then he says "ITS TIME FOR THE CUTTING TORCH"
    Then next week your new ass end will be in Place, and youll be laughing about the Rear End From Hell
    84-85 Custom Tecate
    1986 Honda 200X Daily Rider
    2006 Suzuki King Quad
    Aug 2004
    Ab Canada
    4,368
    yes it should pull out from the sprocket side........heat it up and use the wood+ BIG sledge ......if that dont work your screwed.
    1985 Tri-Z-
    Problem is the guy that had it before me was a idiot haha he didnt take care off the trike i dont think it was ever washed,im gonna try to heat the axle carrier and give it a healty slam with a block of wood and a big ,i just dont wanna bend the axle cause i dont have a new one of them just the carrier and the entire break set up.
    1983 Honda 110
    1967 Mustang
    Jan 2005
    Spruce Head Island, Maine
    893
    i had a hard time gettin the brake drum off of my trike, i had the O ring in the rong spot, and it prevented it from moving, it would go about 1/4 off and then stop like something harder then a little pice of rubber was stopping it, i just moved it back and forth and it eventually popped the Oring out.
    1983 Honda ATC 200x-shes a beater
    Past Rides:
    1982 ATC Big Red 200e (miss it more than i thought i would)
    1985 200x rode it for about a mile
    Jan 2005
    893
    doubt thats whats up with yours though
    Past Rides:
