Results 1 to 12 of 12
Thread: How Do You Bypass Oil Injection On Tri-Zinger?
    Apr 2003
    Central New York
    1,860
    I got the Zinger running today but the Oil Injection doesnt spring back, Probably due to the Throttle Cable Sticking a bit. I was wondering how is the Oil Injection Disabled, but without taking the Parts off. I want to leave it so I can put her back to Stock for future buyers. I would just feel more comfortable mixing the Gas myself than relying on that Oil Injection System.
    84-85 Custom Tecate
    1986 Honda 200X Daily Rider
    2006 Suzuki King Quad
    springville, PA
    6,185
    well couldnt you just mix the fuel yourself and not have to worry about the injection?
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    Aug 2004
    Ab Canada
    4,368
    just dont put oil in the injector and plug off the little line that runs to the cylinder-like the fitting on the cylinder itself for the oil line and your good to go.
    1985 Tri-Z-
    Apr 2003
    Central New York
    1,860
    woo hoo
    Thanks, I just wasnt sure If it would pump air and that might be bad. I cant wait to have this little tricked out ride rippin on my lawn racing my niece with my Tecate after I teach her how to ride. I think I can take her. Then shes up for sale.
    84-85 Custom Tecate
    Dads is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2002
    Richmond, NH
    219
    It will not suck air till it goes to hell from running with out oil in it.
    If you wish to use it again you must pull it and block off the hole.
    Feb 2005
    Canada
    663
    i have a ty175 but the injector hose goes into the lower end can i still block it off and use preminx?
    Washingtons Crossing, Pa.
    2,977
    You just have to make sure you're not sucking any air into the crankcase and you will be fine. Does anyone know if the injector block off kits sold for the Blaster will work on the 175 motor?.
    Fresno Ca
    2,695
    On my jetskis we just dont put oil into it anymore and mix it ourselves. I dont see the need for a blockoff if you dont put oil into it its not going to work.
    Dec 2002
    Richmond, NH
    219
    Quote Originally Posted by NOS_350X
    internal pumps
    It will run fine till the pump goes to hell and it sucks oil out of the gear box.
    or sucks air and leans it out to much. can we say bore job or new piston and cylinder.
    I did a blaster. just cut a pease of aluminium plate 1/4 thick. Drill bolt holes and a gasket good to go. I just cut it square and grind to fit.
    holmstrom is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2005
    bryan ohio
    221
    Ive been running mine with the pump still in, not the one im having problems with , the other one. Maybe i should take mine off and block it off. Turns out that without the cover on there its a big airleak.
    2 125 yamaha tri motos
    1 yt175
    1991 blaster
    Nov 2005
    bryan ohio
    221
    How about you plug off the lines to the carb and leave the oil pump hooked up. Run the line that goes to the carb into the top of the oil jug. put some oil in jug. The pump still is pumping oil so it wont go bad . It'll just cycle the oil.
    1 yt175
    1991 blaster
    Feb 2005
    Canada
    663
    makes sence but i dont have a line that goes into the carb just goes straight to the bottom end. i have a feeling the guys at the shop ****** it up and didint hook up the hoses right.
