Results 1 to 15 of 19
Thread: The Revenge of The Rusty Gas Tank...
    May 2005
    Nome Alaska
    147
    Alas, my venerable ATC 110's gas tank is overcome with rust and shite, and it's literally killing the machine, so I now wonder, should I get a plastic tank, or should I get some CLR and try to save the 100 bucks?
    Quads are for GIRLS!
    Trikes are for REAL MEN!
    Aug 2004
    Ab Canada
    4,368
    fill it with muratic acid let it sit for 20 mins then dump it out, coat it with kreem or something of the like's do a search on the fourms bout this-
    EDIT: just noticed i got teaching quads a lesson....gd im a post whore....LOL
    1985 Tri-Z-
    May 2005
    Nome Alaska
    147
    Where the hell do I find muratic acid, barring Chemistry class...?
    Aug 2004
    Ab Canada
    4,368
    Quote Originally Posted by KayodicWeazel
    local hardware store will have it-2 bucks a gallon LOL
    1985 Tri-Z-
    May 2005
    Nome Alaska
    147
    Dude, I live in Nome. You can't even get Premium gas here, and we sure as hell dont have a hardware store...
    Aug 2004
    Ab Canada
    4,368
    holy hell...alaska...you dont have a hardware store???? any automotive stoes normally have it......................look in everyshop in your area lol, wost comes to worst ill ship you a few bottels of it.,
    1985 Tri-Z-
    Jan 2005
    Spruce Head Island, Maine
    893
    hmmm when i was in dillingham alasks (tiny town) they had 2 hardware stores, and a NAPA,,, lol dogs pull dogsleds not bobsleds..
    1983 Honda ATC 200x-shes a beater
    Past Rides:
    1982 ATC Big Red 200e (miss it more than i thought i would)
    1985 200x rode it for about a mile
    May 2005
    Minnesota
    What you want to do is order the Por-15 kit for cycle tanks. This product is amazing! I have used it on two motorcycle tanks and it is the best. If you do use it...follow the directions to the letter. You will not be disappointed.
    http://www.por15.com/product.asp?productid=306
    Good Luck!
    ktal74
    Monticello, MN
    84 Honda 200s
    86 250SX
    97 CR250R
    2000 MXZ700
    Jul 2004
    minnesota
    689
    all i ever do if i come across a rusted tank, i just get some bebees from a bb gun and put a bunch of them in the tank and shake the hell outa it, and it has always worked for me and all of the rust seemes to come right off , then i just run some gas threw it to clean it out after that.
    my trikes:
    1983 honda atc 200x-k&n filter
    2002 yamaha raptor 660r, yoshimura slip on, prm grab bars
    1978 chevy nova, 454 v8, bds blower, 150hp shot of nitrous, full roll cage, a real power house.
    1991 chevy s10 4x4 350v8.
    1986 250sx
    YES its fast NO you cant ride it.
    Mar 2004
    37
    Quote Originally Posted by ktal74
    Good Luck!
    Por15 is some great stuff. And yes you must follow the directions to the T. Something I found out that isn't listed on the can in that will eat through a plastic dixie cup. I found out the hard way why you should not let it touch your skin, after i picked up my cup and the bottom came off on me. I had grey hands for a week.
    May 2005
    Nome Alaska
    147
    I'll try the cheap-jack BB method for now. If it doesn't work, I'll just rinse it in muratic acid.
    mikey's250sx's Avatar
    mikey's250sx is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2004
    lancaster, pa
    417
    bb's may be a pain to get outta the tank. i also learned the hard way. my sx tank had a 1" lip on the inside but i used bolts and nuts. i guess bb's will come out of the petcock hole. didn't think of that. por-15 is great. also don't get it on you clothes. i have a pair of jeans with a permanent 4" long wave in the front of the leg.
    Jan 2005
    Slatington PA
    4,372
    You can just use nuts and bolts too. It's possible (???) with the BB's that some might lodge in the seems at bottom of tank and you won't get them out.
    Use large enough N&B's that that can't happen.
    dooner17 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2005
    NB
    293
    Tomorrow I'll be purchasing some muratic acid. My motorcycle gas tank is extremely rusty and the kreem kit fell off. It's a mess. I currently have my 3-wheeler gas tank on it and get a lot of looks.
    Apr 2005
    Mississippi
    36
    A short length of chain will do just as good as bbs or nuts/bolts, and you can get it out much easier.
    86' 250SX
    07' 450R
    07' Foreman
    08' trx250x
