Results 1 to 11 of 11
Thread: Does a Honda XL100 need a battery to spark?
    Nov 2002
    Kirkville, NY
    3,831
    One of my friends just got a 1979 Honda XL100 to fix for another friend. The bike has been sitting and is missing the battery (6 volt) and when we checked for spark it didn't get it. On some old bike the battery was needed just for a spark, is this one of them?
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Aug 2004
    Ab Canada
    4,368
    i do belive it is one of them from the best of my recolection, and i thought they used a small 12 volt battry, there like 20$ at napa for a battery
    1985 Tri-Z-
    Jul 2004
    Mud hill. close to water !
    3,658
    Never heard of that before... a battery needed for spark ?.... wow.
    Currently :
    Aug 2004
    Ab Canada
    4,368
    Quote Originally Posted by bigredhead
    becuse its a closed circuit system (loop) you need the battry or else the current cant go though
    1985 Tri-Z-
    Jul 2004
    3,658
    oh.. then just close the circuit... without the battery !
    Currently :
    Apr 2003
    Spanaway, WA
    1,244
    bridge the gap withs something and see if it sparks, my XL250 has a dead battery in it that only has enough juice to power the neutral light after half an hour of riding, but I leave it in so the bike will run. The battery is just there to keep the lights from dimming while idling or cruising at low RPM
    Hoarder of the finest junk
    '82 YT175
    '83 YTM200
    '85 KLT110
    '86 Moto 4 225
    '84 TRX200 trike conversion.
    '87 Tecate 4
    Rittman, Ohio
    6,276
    Im about 99% positive its one that needs a battery, and Im about 80% sure its a 6v system.
    Nov 2002
    Kirkville, NY
    3,831
    Thanks for the responces. I ordered a battery from denniskirk, $10 and it is listed as a 6 volt.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Mar 2005
    ma
    988
    i have an xl100 and a cl100. both had batteries but the wiring was so screwed up i rewired them so they will run with out a battery.
    so to answer your question no you don't need a battery if you change the wires around.
    but for $10 get the battery.
    Billet Triz 250 parts, Case Savers, Engine Mounts, Boost Bottles, Oil Caps, and Shifters, pm me for info
    Shock Rebuilding, PM me for details TRI-Z Shocks rebuilt too
    My Feedback
    http://www.3wheelerworld.com/showthr...k-for-sblt500r
    Mar 2005
    ma
    988
    and the older ones are they are 6 volt. so you will need a 6 volt charger to charge the battery.
    My Feedback
    rustbucket is offline At The Back Of The Pack Arm chair racerFirst time rider
    pentwater michigan
    180
    First of all to tell you have to find out what type of ignition you have to have. since its honda its going to be behind other makes(not honda bashing buth there bike were behind) if it has an internal rotor for a charging system then yes you need a battery unless you can kick it fast enough to use power from the headlight. But I don't think you would need a battery since the 79 honda 400 hawk i had didn't but then again it had cdi. it could be the points are dirty scrape them off and try it.
    1980 trimoto 125 mods include a ripped seat broke fender and bent handle bars
    1981 trimoto 125
    1971 suzuki ts 185 it will spank a 200x
    1966 gmc 3/4 ton
