well, i just wanted to know if the 86-89 axles will work in an 85 carrier...and please dont reply if you dont know FOR SURE! thanks, cause it gets confusing and doesnt really help me if i have 10 people say it will work and 10 say it wont....![]()
I dont know for sure, so I wont confuse you more and guess, but I just went through the same thing. I have an 85R and the axle was bent, my carrier teeth were messed up as well.... I searched all over ebay for a used 85 axle, and they all seemed to be TRX axles... I ended up just buying a Lonstar carrier and a durablue axle...... mmmmmmmmm shiney chromey parts......![]()
Good luck bud!![]()
1985 Honda ATC 250ES BIG RED
1985 Honda ATC 350X
1985 Honda FL670R Odyssey ROTAX conversion
1993 Honda Type II 200
2003 Honda TRX 90
2006 Honda TRX 90
HI!
I'm sorry to say that 85 250r is all on it's own.
if you change the carrie you can.
I know this to be true with dura blue.
TRIZTUNES!!!!!!!!!!!!!!
ok ,, i have a 88 trx axle in a 85 carrier right now,, it works fine . it takes a little figuring on the sprocket but it works fine.
what do you mean by figuring on the sprocket?
85-86 carriers don't interchange.Originally Posted by TRIZTUNES
