Results 1 to 6 of 6
Thread: 250R axle interchangability
    Jun 2004
    potsdam ny
    1,227
    well, i just wanted to know if the 86-89 axles will work in an 85 carrier...and please dont reply if you dont know FOR SURE! thanks, cause it gets confusing and doesnt really help me if i have 10 people say it will work and 10 say it wont....
    Trackburger's Avatar
    Trackburger is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2005
    Virginia Beach
    254
    I dont know for sure, so I wont confuse you more and guess, but I just went through the same thing. I have an 85R and the axle was bent, my carrier teeth were messed up as well.... I searched all over ebay for a used 85 axle, and they all seemed to be TRX axles... I ended up just buying a Lonstar carrier and a durablue axle...... mmmmmmmmm shiney chromey parts......
    Good luck bud!
    1985 Honda ATC 250ES BIG RED
    1985 Honda ATC 350X
    1985 Honda FL670R Odyssey ROTAX conversion
    1993 Honda Type II 200
    2003 Honda TRX 90
    2006 Honda TRX 90
    TRIZTUNES is offline At The Back Of The Pack Arm chair racerFirst time rider
    Aug 2004
    PA.
    150
    250r Axle Interchangabiltiy
    HI!
    I'm sorry to say that 85 250r is all on it's own.
    if you change the carrie you can.
    I know this to be true with dura blue.
    TRIZTUNES!!!!!!!!!!!!!!
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,248
    ok ,, i have a 88 trx axle in a 85 carrier right now,, it works fine . it takes a little figuring on the sprocket but it works fine.
    Jun 2004
    potsdam ny
    1,227
    what do you mean by figuring on the sprocket?
    May 2002
    Southeastern Wisconsin
    3,658
    Quote Originally Posted by TRIZTUNES
    85-86 carriers don't interchange.
