i wouldnt say it was your coil if its only missing at high rpm sounds maybe more like a carburation problem but for testing the coil if you want, get your multimeter and test from the positive terminal to the negative the resistance should be around 20-30 ohms. If thats ok test from the negative terminal to the spark plug cap this should be around7,000-9,000 ohms. If your resistances are a small amount out you shud be ok, but if there way out i would suggest borrowing another coil just to test if you get the same problem
will
85 Tri-Z "Rumble Bee"
85 250R "Red Rocket"
83 200X "Flat Tracker"
