Results 1 to 3 of 3
Thread: 84 tecate 3 with 84 kx250 ignition system
    can the whole ignition system from a 84 kx250 motorcycle fit a 84 tecate 3 i have all parts of it and i was wanting to know the advantages of it and y should it be done and how easy it to install and how does the stator line up if it is done
    May 2002
    Texas
    2,670
    Yes it will work. Switch the CDI, Coil, Stator and Flywheel. You'll then have a more robust ignition system but you won't have the capability to run lights.
    Swapping is easy if you use proper tools and a little patience.
    1986 Tecate
    1984 Tecate
    1985 Tri-Z
    1986 ATC350X
    1985 ATC250R (2)
    1985 ATC125M (2)
    1982 ATC70 - Original Owner
    175 TriMoto Frame with Pro-Tec Rear Suspension
    3-Wheelin' since '82
    does it match the mark on the stator to the same place where the original stator was
